axle seal repair
I bought my 2004 crew cab used with 58000 miles, $16k i might add, it was a "divorce sale". 4x4 Off road. Anyway I found the leaks when i went to test drive it, i knew what is was. I took it to the local dealer for the repair. Replaced both seals as well as the bearings. Question, do they replace the diff fluid for this repair? Cause if they do, they didn't. I checked the level it was about an inch below the filler level. when I drained it it was black. I put the moble 1 back in. I had the tranny fluid changed while there. They didn't notice the leaks around the cooler lines. Took it back and they had to replace the tranny cooler lines. This place also claims they can flush a tranny for $120. They must be able to get their fluid very cheap.
