Old 04-06-2007, 10:42 AM   #1 (permalink)
DrewShoaf's Avatar
Send a message via AIM to DrewShoaf
engine coolant
what type of coolant will work with our trucks- just wondering if anyone used anything else without problems
DrewShoaf is offline   Reply With Quote
Old 04-06-2007, 11:01 AM   #2 (permalink)
bbomar's Avatar
Re: engine coolant
Originally Posted by DrewShoaf
what type of coolant will work with our trucks- i thought i remb seeing under the hood to only use nissan matic type j i think- just wondering if anyone used anything else without problems
J-Matic is Transmission Fluid.
Engine Coolant, you can use Prestone, or other Anti-Freeze.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Old 04-06-2007, 04:46 PM   #3 (permalink)
Re: engine coolant
My service advisor told me the other day I could use any ethelene- glycol (green) based anti-freeze.
04 White SE, CC, 4x4,BT,POP/Capt.,Util. Bed package,Mud Guards,Floor Mats. Born on April Fools Day. Gas Whore.
Remember; Electrical wiring is no hobby.
electricjohn is offline   Reply With Quote
Old 04-06-2007, 11:55 PM   #4 (permalink)
Lurchdubious's Avatar
Send a message via AIM to Lurchdubious
Re: engine coolant
which lasts longer, the green or the yellow? and which is supposed to come stock w/the '04 titans?
2004 LE Crew Cab (Silver)~Volant CAI~Flowmaster 40 series~2+ Timing Advance~rear leaf helper springs~Bakflip folding Tonneau~Titanium pedals & Shifter~Billet grill~20% tint~4x4~Big Tow~Offroad~OEM side bars~OEM Cowbell~Heated seats~Hot Leather
"Guns don't kill people, Chuck Norris kills people."
Lurchdubious is offline   Reply With Quote
Old 04-08-2007, 06:05 PM   #5 (permalink)
Send a message via AIM to Jared
Re: engine coolant
In stock form you have green. Don't put garbage in your truck, get the Nissan long life antifreeze.
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 04-08-2007, 10:28 PM   #6 (permalink)
Re: engine coolant
Here is the MSDS shee on Nissan coolant.
Dr. Chaz is offline   Reply With Quote
Old 04-09-2007, 12:12 AM   #7 (permalink)
Send a message via AIM to xworrallx
Re: engine coolant
I agree, go with the Nissan.
xworrallx is offline   Reply With Quote
Old 04-09-2007, 03:07 AM   #8 (permalink)
Leadsled124's Avatar
Re: engine coolant
prestone has new green "mixes with all types" antifreeze. dealers said its fine to use cause thiers is $25+ a gallon.
'06-Uprev/Stillen Longtubes/JBA Kat-bak/S&B/ 4"Ram/PGM/Trutrac...
Leadsled124 is offline   Reply With Quote
Old 04-09-2007, 09:24 AM   #9 (permalink)
Re: engine coolant
Here are the MSDS sheets for Nissan LL and Peak Global coolants. Check out the formulations, it’s the closest match I have seen so far.
Old 04-09-2007, 09:34 AM   #10 (permalink)
Nissan Mike's Avatar
Re: engine coolant
This may help you,on any warranty situations,Nissan will deny the claim if the dealer did not use OEM ATF or Coolant.These are the only 2 fluids Nissan is worried about contaminating their systems.
Old 04-09-2007, 11:00 AM   #11 (permalink)
Re: engine coolant
Dealer told me if anything happens i can hold them accountable. Theres nothing special in nissans stuff. unless they are putting that new magical cooling moon powder in it now. shailey and RB use prestone so thats all i need to know
Old 04-09-2007, 03:44 PM   #12 (permalink)
Re: engine coolant
Yeah pretty safe statement,by the time the corrosion in the cooling jackets in your cylinder heads eat through you'll be so far out of warranty they won't even care.
My point Leadsled is don't just dump any old crap at Pep Boys in there.
Old 04-09-2007, 05:02 PM   #13 (permalink)
CLG
Re: engine coolant
I think they want you to avoid the Dex- cool compatible stuff. You should be able to find something at the auto store, but like nissan mike said just dont dump anything in there.
CLG is offline   Reply With Quote
Old 04-09-2007, 05:57 PM   #14 (permalink)
Re: engine coolant
hmmm, well the stuff i bought definatly wasnt cheap, but it wasnt as much as stock stuff. after i figure out what thermo works or i put the stocker back in maby ill try the stock stuff for piece of mind. i usually dont keep trucks past 100k miles long anyways, i do a lot of driving for work. i would never use dex cool in a non GM, its orange and sopossed to be for aluminum radiators?
Old 04-09-2007, 06:31 PM   #15 (permalink)
CLG
Re: engine coolant
Nooooo not true anymore GM original dex cool was orange, but has since been reformulated a bit Toyota red is almost the same thing as dex cool and almost all the coolants are dexcool compatible. Its getting harder to get real green.
Coolant smell when engine is under a load dgs1966 Titan Towing & Hauling 3 11-08-2006 01:42 PM
Engine Coolant Temp Sensor kirk94 Titan General Discussion 4 06-16-2006 09:50 AM
Anyone change their engine coolant yet? markislive78 Titan General Discussion 8 12-29-2004 09:19 PM
Titan Leaking Coolant/Engine Belt Problem oncloudnine74 Titan General Discussion 28 09-29-2004 05:52 PM
Titan Leaking Coolant/engine Belt Problem oncloudnine74 Titan Problems & Dealer Service 7 09-21-2004 08:07 PM
