2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
The absolute best way to install is to also replace the axle seals, which requires replacing the outer bearings and associated snap rings. Of course if you get the TruTrac installed w/o new seals (The service manual says that the seals must be replaced any time you pull the axle shafts)and the seals start leaking, the dealer might not remove the rear diff cover and discover the TruTrac, and proceed with warranty replacement of the axle seals and outer bearings. (a little bird told me that)
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
