Old 04-14-2007, 10:06 PM   #1 (permalink)
Transmission concern - is this normal ?
Hello,
A couple of months ago we drove through Cajon Pass in southern California and I noticed that the transmission temperature nearly moved into the H area as we were climbling. We were driving with a 6000 lbs trailer in 3rd gear at about 50mph. I had to slow down to a trickle to keep the temperature from going into the H zone. I pretty much had to line up behind the single lane of trucks going 30-40mph. This is a 2006 Nissan Titan SE 4x4 w/ 17K miles, tranny fluid never changed and outside temperature in the 40s, no wind, A/C off, engine temp. normal.
I have never seen this happen before and I was wondering if this is normal or an indication of a tranny problem. My transmission temperature has always stayed slight below the middle even when climbing hills w/ trailer in tow in the hot Arizona weather.
Thanks,
Mike
speediq99 is offline   Reply With Quote
Old 04-14-2007, 10:09 PM   #2 (permalink)
Re: Transmission concern - is this normal ?
I would have it looked at considering the ambient temp. It probably isn't an issue because you payed attention to it, and corrected it before a problem, but I would at the very least get a fresh tranny flush from the dealer and have them report the condition of the old.
2007 Crew LE - OR - Tow - Black
RoskO is offline   Reply With Quote
Speed bumps & dips raising concern johnjitsu Titan Problems & Dealer Service 2 10-18-2006 11:43 PM
Normal Transmission? Tenoldmen Titan Engine, Transmission & Drivetrain 8 04-06-2006 09:35 PM
To whom it may concern... admorris Titan General Discussion 33 12-16-2004 08:17 AM
This does not concern the Titan (yet!) but still an interesting read. O'silent1 Off-Topic Discussion 2 07-22-2004 02:06 PM
differential concern and worry juma Titan Engine, Transmission & Drivetrain 7 06-03-2004 06:22 PM
