Old 05-07-2007, 08:29 PM   #16 (permalink)
tmassey's Avatar
Re: Why does my titan bounce..
I have an 04 2wd cc. I have the same thing at about 47 mph. I have 46000 on the original Goodyears. Replacing them this Saturday with Michelins, I'll see if it goes away.
tmassey is offline   Reply With Quote
Old 05-07-2007, 10:03 PM   #17 (permalink)
Aquaholic's Avatar
Stock structs usually last about 25k miles on a heavy truck. I put my money on the struts.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
RIVER TRASH C.O.R.R. Junky
Aquaholic is offline   Reply With Quote
Old 05-08-2007, 05:53 PM   #18 (permalink)
FreezyTitan's Avatar
I have the same thing on my 04 that only has 21K miles on it. I think it is the shocks as well. Could it be the shocks even with low miles is my question??? The shocks are old because it is a 04, but not too many miles.
Titan Sold 12/07:
With the following items included: Kenwood DDX6019 Receiver, G-510 Navigation add-on, Rearview Camera, iPod Control, JBL 6x9 Front & 6.5 Rear Door Speakers, tonneau cover, billet grille w/logo cut-out, & remote start.
Leftovers: 22" Granite Alloy GA3.6 w/General Grabber UHP (305/45VR22), Leveling Shackles, Tech12Volt box with 10" Memphis sub, and a 700W Profile amp.
FreezyTitan is offline   Reply With Quote
Old 05-15-2007, 08:38 PM   #19 (permalink)
tmassey's Avatar
got new michelin cross terrains Saturday, no more bounce at 47 mph. I had 46000 on the Goodyears. The ride is smoother than when it was new.
Old 11-28-2007, 11:31 AM   #20 (permalink)
Send a message via MSN to windowskilla Send a message via Yahoo to windowskilla
Ok My truck is a BRAND NEW '08 Titan King cab with 525 miles on it and guess what, certain roads, not so certain speeds and I get bounce bad enough to get sick... curious to see what anyone thinks of this.
windowskilla is offline   Reply With Quote
Old 11-28-2007, 11:47 AM   #21 (permalink)
donmecca's Avatar
FYI: My truck bounces at 70 to 80 mph and it still does this after my mechanic installed PRG's 4" spindle kit (which has CST spindles, 5500 bilsteins in front and DRs on the rear).
I still need to post pics, I just got back from Cali for Turkey-day.
My mechanic drove it prior to the PRG kit install and then after and he says I need a high speed wheel balance and suggested a local speed shop that he uses for front end alignment.
Also,he had my truck aligned at the speed shop after the kit was installed and I'm rolling on Michillen's MXs with only 1000 miles on them.
I let you know if this works, plan to have it done this weekend.
Don Mecca
Titan LE CC
May '04
A bunch of stuff, not all of it works
donmecca is offline   Reply With Quote
Old 11-28-2007, 11:49 AM   #22 (permalink)
Yahooligan's Avatar
Is this your first truck? Different roads will cause different vehicles to "oscillate" at various speeds. That is, the seams or bumps in the road will cause vehicles with certain wheelbases to bounce or see-saw if the speed is right. This is most noticeable on trucks due to the suspension and longer wheelbase. Speeding up or slowing down may cause it to go away or be less pronounced, but in most cases that's just the nature of the beast. If you were experiencing this on ALL roads and a given speed then it would be a truck issue, but your problem is just with certain types of roads.
For me, this happens when driving on I-10 towards Palm Springs, the concrete road like to make my truck bounce.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
Old 11-28-2007, 11:57 AM   #23 (permalink)
It is indeed, however Ive talked to alot of people who own assorted other trucks and they all have told me that some bouncing with heavy trucks and no load is normal but this is really bad ... pretty much the only time it doesn't bounce that bad is on <1 year old low speed roads, and at speeds below 10mph... adding/reducing speed seems to have little bearing on the bounce.
Vegas does have some crappy roads no doubt but it even does it going 60 on the new third lane of I-15 heading towards LA.
Old 11-28-2007, 12:16 PM   #24 (permalink)
bbomar's Avatar
News Alert!!!!!!
Trucks Bounce!!!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Old 11-28-2007, 12:33 PM   #25 (permalink)
Fair enough for nominal bounce but this is like riding a jackhammer... also I suspect that it being brand new could be some of the problem but still... trust me, this is excessive.
Old 11-28-2007, 01:21 PM   #26 (permalink)
Yahooligan's Avatar
Are most of the roads out there concrete laid in sections, so there's a "thump bump" every 8 feet or so? These are the worst and will cause trucks to bounce when a car that has softer suspension won't.
I don't know what's worse, the hard bounce or the see-saw with long-wheelbase trucks. Some folks have litterally gotten sick from the see-saw, it's a lot like going up and down waves on a boat.
I get a pretty good firm bounce going on a number of socal freeways, but I-10 is by far the worst. It bounces enough to cause my flex-mounted iPod to bounce up and down a good 3 inches or so, That's a lot considering how stiff the flex neck is.
I would imagine this is more pronounced on Off-Road or Pro4X equipped trucks that have firmer shocks, but I can't say for sure as I don't have either of those packages.
Old 11-28-2007, 03:00 PM   #27 (permalink)
So I should just quit *****ing and either get a smoother riding car or enjoy the ride? Frankly Ill take my chances with the Titan... funny thing is, the Ford Fusion I got from enterprise while my truck was in the shop did the exact same thing on the same road only (of-course) a little less pronounced considering the obvious differences.
Also bbomar ... thanks for being ummm concise?
Old 11-28-2007, 04:34 PM   #28 (permalink)
I get the same hop/bounce between 40-50 mph, new tires helped, but did not eliminate it.
SOLD--04 SE 4x4 CC, Galaxy, RF Bench, Utility, BTow
jabajet is offline   Reply With Quote
Old 11-28-2007, 06:12 PM   #29 (permalink)
roy365's Avatar
Mine does it as well.......new rims, tires, shocks and still there. I coulda swore i got ahold of a bad piece of crack rock though until i read this post. Maybe just the wheelbase dimensions?????
0-60MPH@5.60 & 1/4 mile@14.25 F/S/T
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 11-29-2007, 12:18 PM   #30 (permalink)
joeinstl's Avatar
I have the same bounce around 45 to 50. It's not that big of a deal to me, only lasts for about 1/2 a second then I'm cruising along at 70 MPH.
2005 SE KC 4X4
"If there must be trouble, let it be in my day, that my children may have peace." - Thomas Paine
joeinstl is offline   Reply With Quote
