Re: The Gears
you don't want bigger gears bro,lol not for racing anyways, you will hit your rev limiter faster than fu#k and wont be able to do **** for the back half of the track.. even uprev can't re-calibrate the speedo with gear swaps but i think if nuff people wanted it they could probably do it.. you could get your speed limiter removed and do the bigger gears though..
also if you ever plan on doing drag radials it is lot easier to do a effective gear ratio change by just going to a shorter tire.. like me with 2.94 rear end with 28" tire i cross the 1/4 mile at 5500rpms in 3rd gear and ends up being like a 3.23-3.30 gear ratio i believe .. still making little power, but if you change to 4.10 you'll definatly shift into 4th and that imo is a bad thing, 3rd is the money gear..
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
