Old 05-29-2007, 10:12 PM   #1 (permalink)
Smokey06's Avatar
Angry Can you defeat the traction control,or add a REAL diff-lock?
And I mean "SLIP". The more I drive this truck,the more I hate computers. Is there a way to disable the traction control,and also can I add a different locker other than "Tru-Trac"? I want an Eaton or Detroit locker,had a good bit of fun in my Silverado,just wondering if it's able to be added in the Titan?
Smokey06 is offline   Reply With Quote
Old 05-29-2007, 10:31 PM   #2 (permalink)
baseballfanz's Avatar
Re: Can you defeat the traction control,or add a REAL diff-lock?
As far as I can tell, you cannot disable the ABLS (Slip). I have heard but no confirmation that ARB is suppose to release their "air locker" system for the Titan.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 05-29-2007, 10:55 PM   #3 (permalink)
There were some posts about pulling the fuse or modding the fuse with a switch. I think it defeats ABS and ABLS and lights the dash up like an X-mas tree.
Old 06-03-2007, 09:30 PM   #4 (permalink)
loufish's Avatar
You can install a Tru-Trac diff, that will work fine with brake/traction control system...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-03-2007, 10:36 PM   #5 (permalink)
Smokey06's Avatar
I'm wanting to add the locker later,but I want to get rid of traction control right NOW.........it's kind of,well,
How do I turn off the traction control? Work Horse Titan General Discussion 16 02-18-2007 08:55 PM
stability control traction system? Roadrunner Titan General Discussion 8 12-30-2006 10:00 AM
VDC Traction Control on Titan XE All Wired Titan General Discussion 1 10-10-2005 10:20 AM
ABLS vs. traction control vs.VDC richardminco Titan General Discussion 7 09-15-2004 01:03 PM
