Old 05-31-2007, 12:27 PM   #1 (permalink)
100 degree temps and oil
So we are getting high temps down here..
From 96 to 104 degrees temp, So should I use a different oil than the 5w-30?
I have never looked into this different oils for different temps, but I really want my titan to last as long as it can...
any help with this???
thanks
maurimx is offline   Reply With Quote
Old 06-03-2007, 10:26 PM   #2 (permalink)
loufish's Avatar
Re: 100 degree temps and oil
I wouldn't switch oil grades, BUT I would use a good synthetic. I'm a Moble 1 guy, but there are others.
The synthetics handle the heat better then dino oil...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-04-2007, 02:02 PM   #3 (permalink)
thanks for the tip
Old 06-04-2007, 02:31 PM   #4 (permalink)
sudden urge's Avatar
With constant temps like that, I would only use a synthetic oil.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 06-04-2007, 05:33 PM   #5 (permalink)
Send a message via AIM to Jared
I've always used regular dinosaur oil and probably always will until the prices get closer or syn is all I can buy. 5-30 is fine for those temps, but you need to keep your oil change intervals closer. I recommend 3k.
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 06-04-2007, 05:58 PM   #6 (permalink)
thanks..
I always use synth..
But I will make the intervals closer, like recomended.
Old 06-08-2007, 08:48 AM   #7 (permalink)
SupraTitan's Avatar
I'd run a slightly thicker lube, I really like mobil 1 0w-40, its on the lighter side of the 40wt scale and should have no issue going a minimum of 7500 miles. Another good oil is the Castrol syntec 0w-30,(don't go near the 5w or 10w-30 syntec), the 0w-30 should say "made in Germany" on the back of the package, only place i've ever found it is at autozone. Its at the higher end of the 30wt scale, almost a 40wt and also carries an acea A3 certification. Both oils have excellent pumpabilty, something rather important with a dohc 32 valve engine while still maintaining a higher viscosity. Basically they are both the perfect oil for extreme temps at both ends of the spectrum. My truck doesn't even strain on a -25 degree cold start with either oil.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
SupraTitan is offline   Reply With Quote
Old 06-08-2007, 09:09 AM   #8 (permalink)
loufish's Avatar
Most of todays modern engines are designed to run 5-30 type oils, and even the engine cooling aspect is designed around that. Lighter oils move faster thru the engine including drainback and this aids in the oil cooling of the engine.
Our engines use direct opening valves, no hydraulic lifters to keep pumped up.
Want to bump up to a 40 grd oil? If it's a synthetic then fine, it will flow, but theres no real need to change grades, best upgrade in extreme temps(hot & cold) is switch to synthetic...
Born 9/2004
2002 Honda XR650R
Air Conditioning Temps TITANATOR Titan Problems & Dealer Service 11 08-06-2006 09:09 PM
Transmission Temps going way up!! Help! doctor steve Titan General Discussion 14 03-26-2006 09:07 PM
Diff temps... loufish Titan Engine, Transmission & Drivetrain 15 11-29-2004 08:51 AM
How hot is too hot?? Rear diff temps?? cttitan Titan Engine, Transmission & Drivetrain 44 10-31-2004 02:34 PM
