Old 06-04-2007, 02:32 PM   #1 (permalink)
4wheelpeel's Avatar
Air intake flaw
So I am sure all of you know it was a poor idea to have a tube going into the fender where mud and water can be sucked up into the motor. I crossed a 2 foot deep creek this weekend and the titan started spuddering on me. I checked the filter and it was wet. I let it dry and its cool now but I was scared for a while. Anyone know a diy fix for this problem. I took a nissan altama through the same creek and it was fine. you would think a 4x4 titan could handle it.
4wheelpeel is offline   Reply With Quote
Old 06-04-2007, 02:34 PM   #2 (permalink)
jasonmotox's Avatar
Re: Air intake flaw
it could handle it without the straw sucking up the creek water man!
correction.. is this a do it yourself mod or is this the stock set up?
[IMG][/IMG]
07' Osceola Swamp Runner
jasonmotox is offline   Reply With Quote
Old 06-04-2007, 02:35 PM   #3 (permalink)
sudden urge's Avatar
Re: Air intake flaw
You need to get the XE model wheel well. For some unknown reason the XE wheel well has no openings like the SE and LE models. There's a few old threads here about it.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
sudden urge is online now   Reply With Quote
Old 06-04-2007, 02:36 PM   #4 (permalink)
vipzach's Avatar
Re: Air intake flaw
I think someone on here changed their fender liners to the XE liners and it really helped. If I remember correctly, the SE and LE liners are weaker or less protective than the XE liners????
vipzach is online now   Reply With Quote
Old 06-04-2007, 02:39 PM   #5 (permalink)
4wheelpeel's Avatar
Re: Air intake flaw
can you just take out the straw. I did a search and no luck. I do not want any thing lower than where the filter is. I dont cross many rivers or anything. but it seems even a deep puddle would do some damage.
Old 06-04-2007, 02:40 PM   #6 (permalink)
4wheelpeel's Avatar
Re: Air intake flaw
This is how it is set up stock. I think it was a bad idea putting the intake hose under the front fender.
Old 06-04-2007, 02:42 PM   #7 (permalink)
Re: Air intake flaw
I wouldn't take out the fender intake. If I remember correctly, the XE plastic wheel well was like $35 each and you only need one imo.
Old 06-04-2007, 06:42 PM   #8 (permalink)
TitanBlue's Avatar
Re: Air intake flaw
Does the "Air Box Mod" remove the snout I think the OP is referring to? Cut off the snout and no more worry???
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 06-04-2007, 07:20 PM   #9 (permalink)
aldaman's Avatar
Re: Air intake flaw
I know this thread is for the intake mods/design, but FYI..Whenever it looks like water/muddy water gets sucked into the engine, you can do a quick fix on the trail by unscrewing your sparkplugs, spraying WD40 into the heads and cranking the engine several times with out them installed. this method pushes out the water that may have gotten into the cylinders. Hopefully this lessens any engine damage.
'04 Titan Crew Cab 4x4-Off Road Package / Big Tow
Add-Ons:
-2.5" Leveling Kit
-Husky Floor liners
-Drop in K&N Air Filter
-JBA Cat Back exhaust
-7" Head Rest DVD Monitors
-BFG KM2s (305/65/17) Tires
"My old Ride"
aldaman is offline   Reply With Quote
Old 06-04-2007, 08:38 PM   #10 (permalink)
Re: Air intake flaw
The air box mod shortens the tube inside the box, not outside.
Old 06-05-2007, 07:21 AM   #11 (permalink)
4wheelpeel's Avatar
Re: Air intake flaw
why not shorten or remove the tube outside?
Old 06-05-2007, 08:34 AM   #12 (permalink)
Re: Air intake flaw
The tube going into the fender acts as a velocity stack and draws in the coolest air possible. If you remove the tube, you lose the velocity stack effect and will be drawing in hot engine compartment air.
Old 06-05-2007, 08:47 AM   #13 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Re: Air intake flaw
did you really go through 2 feet of water in an altima??
2° | AEM Brute Force | 2" NCD Leveling Kit | PRG Shackles| 20" Konig Coastal Wheels w/ 305/50 R20 Nitto Terra Graplers | Aries Bull bar w/ 2 Hella 500 Driving Lights |Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | BB's Extang Trifecta Lease with option to buy
The Urinator™
DeadRiver is online now   Reply With Quote
Old 06-05-2007, 09:27 AM   #14 (permalink)
4wheelpeel's Avatar
Re: Air intake flaw
Hell yeah 94 altama gxe! I also climbed a dirt hill that a toyota tacoma in 2wd could not get up I had to jump the top of the hill so my frame would not get hung. Man I miss that p.o.s.!
Old 06-05-2007, 01:24 PM   #15 (permalink)
54warrior's Avatar
Re: Air intake flaw
Here was my solution, cost me about $20:
LF Inner Fender Coverage Solution WIP...
Who wants an intake Ravelo Texas Forum 2 04-10-2007 08:29 PM
cold air intake or hot air intake? BO$$ Hawler Titan Performance Modifications 19 03-03-2007 12:31 PM
Weak rear bumper design flaw? DeTitan Titan General Discussion 18 01-18-2006 09:58 AM
Minor design Flaw buzz11 Titan General Discussion 17 08-19-2004 11:43 PM
Designer Flaw On Column Shift? Titan XE Titan Problems & Dealer Service 9 08-18-2004 12:56 PM
