Old 06-04-2007, 04:09 PM   #1 (permalink)
Rear Differential Mod
OK maybe this is a little extreme but having read several threads on rear differential problems I was thinking that maybe there is an aftermarket gearing that would replace stock and give much better performance. If the Titan is out of warranty would this be a practical solution? I don't know where Nissan gets its differential but just possibly that same manufacturer makes a stronger one for a different customer that would retrofit the Titan.
goldwing is offline   Reply With Quote
Old 06-04-2007, 04:15 PM   #2 (permalink)
Blackbeauty's Avatar
Re: Rear Differential Mod
Currently there are NO aftermarket gears available for the Titan. The only option is a Tru-trac. Some gearsets are supposedly in the works from 2 major manufacturers, but so far, we have not seen any..... Check back later.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 06-04-2007, 07:25 PM   #3 (permalink)
Titan1080's Avatar
The stock ring and pinion in our rear axle has nothing to do with the rear diff failures. just replace the diff with a Trutrac and you'll be set for the life of the truck.
AKA, Rusty Whore™
2004 Titan XE KC 4x4 DOB 12-15-2003
Compare your truck to mine and then kill yourselves!
Click Here to see a list of things I did to void my warranty
My Picture Gallery
Titan1080 is offline   Reply With Quote
Old 06-10-2007, 10:44 AM   #4 (permalink)
titan2005's Avatar
what would it cost to replace it with a Trutrac? break the cost down with the price of Trutrac and Labor.
2007 CC SE 4X4 BT MAJESTIC BLUE
titan2005 is offline   Reply With Quote
Old 06-24-2007, 08:13 PM   #5 (permalink)
coachflip's Avatar
Send a message via AIM to coachflip
search man, that has been covered to a large degree many times.
Brent
2004 CC 4X4 w/ProComp Stage 1
DR Coilovers/Bilstein Rears/TC Upper Arms
Deaver 1" pack w/3" block (5" rear lift)
CarPC with GPS/DVD/MP3/XM/Internet
eD6500's front
eD EU700's rear
eD 11kv.2's subs in upfire box
coachflip is offline   Reply With Quote
Old 06-25-2007, 06:06 AM   #6 (permalink)
The Trutrac is around $550 to 570; carrier bearings are around $35; install is $200 to 400.
Old 06-25-2007, 08:10 AM   #7 (permalink)
titan2005's Avatar
Thanks, dude
Old 07-11-2007, 10:21 PM   #8 (permalink)
Are you sure a True Trac would keep the differential from failing?
dirtyd is offline   Reply With Quote
Old 07-12-2007, 04:38 PM   #9 (permalink)
TitanBlue's Avatar
When a "supermoderator" chimes in and doesn't dispute the facts shared by members who have been here for years (see their sigs and avatars), you can trust the answer. Yes, TrueTrac works, no worries. Doesn't turn it into a 1 Ton Dually Diesel, but outstanding 1/2 Ton Pickup! Loving mine!
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Rear Differential Kit flyguy Titan General Discussion 4 08-28-2005 08:23 PM
Checking Rear Differential jpf2500 Titan General Discussion 18 03-03-2005 12:56 AM
Rear Differential BIGGERSTUFF Titan Engine, Transmission & Drivetrain 23 11-21-2004 04:15 PM
Rear Differential fix.......maybe CoachBoone Titan Problems & Dealer Service 5 07-30-2004 03:03 PM
rear differential Higgy1 Titan General Discussion 15 07-25-2004 06:57 PM
