Old 06-09-2007, 08:19 AM   #1 (permalink)
Question rear wheel seals
can anyone tell what a reasonable price would be to have my rear wheel seals redone? i only have 53,000 on my '06 titan. i am hesitant to take to a dealer. would this be an easy job to do myself. i am only somewhat confident in my ability to repair the seals.
joewalhea is offline   Reply With Quote
Old 06-09-2007, 09:31 AM   #2 (permalink)
Demondw3's Avatar
Re: rear wheel seals
If it is the rear axle seals don't be hesitant take it to the dealer and have it done for free under warranty. I had about 66k on mine when I brought it in to the dealer and didn't pay a dime for it. I don't think anyone has had to pay for the replacement of the axle seals.
check out my trucks transformation.
http://www.kodakgallery.com/Slidesho...Uy=8mexzr&Ux=0
Demondw3 is offline   Reply With Quote
Old 06-09-2007, 03:39 PM   #3 (permalink)
NorCal 4x4's Avatar
I believe they must press the bearings off the axle for this job, or crack them off and press new ones on. That's what they did on mine anyway. Said it would have been roughly around $500 if it wasn't covered by the power train warranty ... 60K mile/5yr.
Old 06-09-2007, 04:30 PM   #4 (permalink)
kartman's Avatar
If they are not leaking dont worry about it, its real expensive as well since you need new bearings.
Rebar Wrangler
Old 06-09-2007, 05:42 PM   #5 (permalink)
Yes, expensive and requires specialized tools.
Old 06-09-2007, 08:07 PM   #6 (permalink)
pgthe1's Avatar
DMZ-FAB did mine for 200.00 bucks with fresh oil.
pgthe1 is offline   Reply With Quote
Old 06-10-2007, 07:59 AM   #7 (permalink)
loufish's Avatar
If you have to ask, you should have someone else do them...Not a good first time project...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Rear axle seals leaks. Please report. Herbpov Titan Engine, Transmission & Drivetrain 273 10-07-2008 02:22 PM
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 03:41 PM
Seals leaking in rear diff kongmen Titan Engine, Transmission & Drivetrain 10 07-26-2005 09:08 PM
Rear seals and bearings relplaced COTitan Titan General Discussion 1 01-17-2005 02:48 PM
Rear Window Seals Leaking, rear seatbelts blow Half Shovel Titan Problems & Dealer Service 7 12-06-2004 05:18 AM
