Old 06-11-2007, 04:32 AM   #1 (permalink)
BK19702's Avatar
Changed Rear Diff Fluid
Well, changed the rear diff fluid this weekend after 21,000 miles. I would have taken pictures, but there was nothing of real interest to see. I drove the truck around the block a little to warm up the oil, then got to work. The existing fluid in the diff looked pretty good, no burnt smell, no siginificant metal shavings to speak of. There was a little less that 1/8" of mung (technical term) on the drain plug, which was less than I expected based on what some other posters have seen. So, my laundry list of equipement:
1 - Tube of Permatex thread sealant (about $4)
3 - Quarts or Amsoil Severe Gear 75W-140 Synthetic ($10 each - preferred customer pricing, completely worth it by the way)
1 - MeasuFunnel from AutoZone complete with hose and on/off flow cap (about $6)
I have to say, the funnel from AutoZone was a godsend; just filled the funnel with the new fluid, capped it, inserted hose in the fill hole, held the funnel overhead (resting my arm on the spare), turned the cap to 'on' and let it drain right into the pumpkin. Pretty easy and no big mess to speak of. Of course prior to this I applied Permatex to the drain plugged and torqued to 20 ft-lbs.
Nice part about the funnel is I was able to measure exactly 2.0L for the fill; basically two whole quarts (946ml each), then a portion of the third to 100ml on the funnel. Level was right where it was to begin when I checked the original fluid. So, some moderate clean up, more Permatex, and torqued the fill bolt to 25 ft-lbs. Once more around the block and checked for leaks....none
So, that was Saturday morning, I've checked back Sunday and this morning after the drive in to work, no issues either. My only thought on improvment would be to use the hand pump that Amsoil sells to pump the fluid into the diff, but that's not really a big deal. Other than that, the money I spend to do it myself is no where in comparison to the lost time waiting at the dealership in addition to the $100 + they would have charged me to do the same thing.
Anyway, I figured I'd share just to add to the database of info for fellow Titan owners.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 06-11-2007, 05:46 AM   #2 (permalink)
Re: Changed Rear Diff Fluid
That funnel sounds interesting, for sure.
Old 06-11-2007, 10:14 AM   #3 (permalink)
Shane06fl's Avatar
I use a hand pump that is for the tall bottles of gear lube. I trim the stem to fit the Amsoil bottles and it works great
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 06-11-2007, 11:25 AM   #4 (permalink)
thclimer's Avatar
When I do mine the next time I'll definitely be getting a pump or the funnel you speak of. I changed mine trying to use a funnel with an extension tube, it worked, but a pump seems to sound like a much better plan.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
Old 06-11-2007, 12:03 PM   #5 (permalink)
TAFOYA'STITAN's Avatar
did it help at any clunks coming from the rear. i get it when i switch from park to drive
TAFOYA'STITAN is offline   Reply With Quote
Old 06-11-2007, 01:00 PM   #6 (permalink)
BK19702's Avatar
I didn't have any clunks to begin with. I changed the fluid as a preventative measure to remove the original oil and any shavings that may have accumulated in the diff as a result of manufacturing, etc.
Old 06-18-2007, 11:47 AM   #7 (permalink)
Justintoxicated's Avatar
I think I have that same funnel with the measuring thing, and the blue on/off twist?
I think I would suggest using the pump though I have the autozone hand pump as well. I dunno guess it depends what you feel like cleaning up afterwards? Sometimes teh pump take forever to return to the "ready for another pump" position since the fluid is so thick..
Changed my Diff Fluid hunterdrake Titan General Discussion 10 06-14-2006 09:56 AM
Changed Rear Diff. 3rd Time Fluid to Mobil 1 Titan XE Titan General Discussion 50 03-14-2006 08:54 AM
Had the oil and rear diff. fluid changed today. Flight Test Titan Engine, Transmission & Drivetrain 7 08-03-2005 10:47 AM
Changed rear diff fluid GO_VOLS! Titan General Discussion 11 05-16-2005 10:39 AM
04 Rear Diff. Fluid Changed Again 7,836 Mi. Titan XE Titan Engine, Transmission & Drivetrain 2 02-15-2005 06:38 AM
