Old 06-18-2007, 10:50 AM   #1 (permalink)
Question Matic J Fluid
I was a Autozone the other day, and while I was looking at different fluids for a tranny flush, I noticed that Valvoline Maxlife, which is Dexron/Mercon, states on the back, that it is suitable for Matic J trannys. What do you guys think?
RuggedTitan is offline   Reply With Quote
Old 06-18-2007, 11:40 AM   #2 (permalink)
Justintoxicated's Avatar
Re: Matic J Fluid
I would stick with the Nissan Matic-J or Amsoil. Someone posted abotu using I think it was castrol Matic-J complient and said their truk did not shift properly. Since you should flush if changing to a Non-Syntheticand that costs a fortune I would put in some decent oil, backed with a warranty. Does that Oil Gaurantee it is fully Matic-J compliant? Will they pay to fix your truck if it causes a failure?
Old 06-18-2007, 11:51 AM   #3 (permalink)
Re: Matic J Fluid
Not using J-matic will void your Trans warranty.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Power Steering Fluid and Matic D????? brassballs1979 Titan General Discussion 5 11-11-2006 04:30 PM
16 quarts of J matic tranny fluid redneckpapa1996 Off-Topic Discussion 12 07-25-2006 04:12 PM
Replacement To J-matic Fluid. ksnow Titan Engine, Transmission & Drivetrain 2 07-08-2005 12:04 PM
Matic J stokie Titan General Discussion 5 04-07-2005 07:52 PM
Nissan ATF J Matic Transmission Fluid phillipyang Titan Parts & Accessories 4 10-19-2004 08:05 PM
