Old 06-23-2007, 12:59 AM   #1 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
***PICS***rear diff after jiffy lube
okay ,, so i know i shouldnt have taken it to jify lube but i did
here are some pics of what happened.
not sure on the extent of the damage but i thought i would get some feed back from you guys as to if my seals are gone or if they just over filled the heck out of it or anything else...i dont know much about rear diffs but i know it shouldnt looko like that.. im taking it bakc first hing in the morning... alos im supposed ot be driving from denver CO to SA TX tomorrow.. should i hold off.. even after the drain it or chekc it out
pics[
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
Old 06-23-2007, 01:01 AM   #2 (permalink)
import2nr's Avatar
Re: ***PICS***rear diff after jiffy lube
sorry for the large pics
scroll to the right ot see them all
*AIRE TBS
Old 06-23-2007, 02:40 AM   #3 (permalink)
import2nr's Avatar
anyone????????
*AIRE TBS
Old 06-23-2007, 02:44 AM   #4 (permalink)
faith+1's Avatar
Send a message via Yahoo to faith+1
It certainly looks like (at the fill valve) that they spilled a bit. But for them to just shake the oil all over the place doesnt sound right... Maybe they oiled all the moving parts back there for fun?
Did you check your diff level before taking it to them? If so you may have had this problem already and been running reallllllly low on the rear diff fluid.
Did you at least make sure they used the SYNTHETIC fluid Nissan recommends now for all Titans? Some places dont have it up to date and use the old stuff, which will work, but Nissan even knows that Synthetic gear oil is better for the diff.
Oh and on the part of should you drive or not - Do you have AAA? If so then go for it :-)
I got a 4X4 04 LE Titan CC, BT, Modded RF - TECH12Volt Sub Box with 12" Mephis Woofers, HIfonics Amp 600 RMS, 6" Pro Comp Lift, Nitto Tires, American Racing Mohave Simi Bead Lock Rims, Rad Flo 2.5 front, Bilstein rears, Brute Force AEM CAI, and Banks Exhaust, Stillen VKProModule.
**Phoenix Dyno Day Thread**
Videos:
Speedworld Meet Video*Not so New *
Firebird Raceway Meet Video
1st Annual Titan Meet Video Compilation
Vid of me up comp
Sobe Torch
Favorite Video of me playing Guitar Hero 2 PS2
Pictures:
My Truck Pictures
Glamis Pictures Thread
DBW™
faith+1 is offline   Reply With Quote
Old 06-23-2007, 02:55 AM   #5 (permalink)
import2nr's Avatar
well ive only had little wet spot on the the under side of the diff .. but that been there since almost day one .... as far as checking the diff level ..i never have nore do i know how to..( but i have takne it ot the dealer ship for my 30,000 maint.. dont they check the diff level at that time) .. i specifed to use the SYN and they did use SYN 75w90 GL-5 Should they have used somthing else?.... no i dont have AAA... is it easy to join... could i join now online and have it active already?
so whne you say it seems its at the fill valve ..... would that cause me to have the diff dripping onto the drive way... its only like about a quarter coin size drop and nothing more .... so is your take that its all residual?
thanks for the response
*AIRE TBS
Old 06-23-2007, 07:36 AM   #6 (permalink)
I don't think even JiffyLubers would be spraying gear oil all over. I think it is leaking onto the driveshaft and the spinning drive shaft is throwing oil all over. Probably a bad pinion seal. Maybe the check valve is plugged, which pressurizes the rear axle and blows seals. (see CJ3Flyers thread on venting rear axle).
Old 06-23-2007, 08:01 AM   #7 (permalink)
DawgBone's Avatar
I agree - When my rear diff blew this is where the leak was. My axle seals were leaking too, but this is where the bulk of the fluid came out.
Old: '04 SE Crew 4x2
New: '08 SE Crew 4x2
Nov 16, 1996, UGA at Auburn, 1st quarter: UGA V almost takes Auburn wide receiver Rober Baker's manhood off for catching a touchdown pass to put Auburn up 7-0. Stupid leash.
DawgBone is online now   Reply With Quote
Old 06-23-2007, 08:23 AM   #8 (permalink)
I think I would get shop rags and Simple Green or other degreaser and clean the area to see if the problem still persists and where the fluid is coming from.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 06-23-2007, 09:59 AM   #9 (permalink)
import2nr's Avatar
okay guys.. i took it back this morning ... they guy who did the work was there and he told me that whne he was pumping the lube in that the hose slipped out and sprayed every where ... he did not hose it down but attempted to RAG it off ... it seems to make sense to me .. ive been parked now for about 30 minutes and havent noticed any leaking ... and when they checked the level it was full.... seems a little to simple of an explaination .. but i hope its the truth.... how long would i need to be parked before noticing another drip mark on the drive way
im going to be leaving in about an hour or so .... ....
*AIRE TBS
Old 06-23-2007, 10:20 AM   #10 (permalink)
DawgBone's Avatar
It may take some driving to heat up the fluid and get it moving around before you see much of a drip.
Old 06-23-2007, 10:25 AM   #11 (permalink)
That is some big pics! Please resize them next time!
Changing the rear lube is so unbelievably easy. And you are
sure to do it right. You can also make sure that it is in fact syn. oil. Hope it all works out for ya.
Old 06-23-2007, 10:55 AM   #12 (permalink)
If they put in 75-90 synthetic oil that is the wrong oil. Nissan specifies 75-140 synthetic. Nissan went to 75-140 sometime in 05.
While the oil you used will work, Nissan changed the spec. for a reason.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 06-23-2007, 10:58 AM   #13 (permalink)
import2nr's Avatar
i already appologized for the pics in my second post afer having realix=zed how large they were
no time to resize
and i will see if i can get them to change it before i leave ... and or just put it in the RIGHt STUFF the next time around
*AIRE TBS
Old 06-23-2007, 11:01 AM   #14 (permalink)
no time to resize
You dont have the BT package so your rear isnt as likely to go as the BT rearends from the poll here of which ones are going. Needless to say You should still put the recomended lube in.
Old 06-23-2007, 05:59 PM   #15 (permalink)
Boost_Junkiee's Avatar
dude, that rear end has the seals blown out of it from overfilling and probably using the wrong diff fluid type. I would use only oem recommend fluids. I know jiffy lube is less expensive and convenient, but you need to make them pay for that **** after you get a quote from nissan to fix it.
Boost_Junkiee is offline   Reply With Quote
