Old 07-22-2007, 03:00 AM   #1 (permalink)
TYTAIN's Avatar
True Trac discount
4x4 Parts offering $20.00 off to Titan Talk members. This is the best price I has seen yet. See the 4x4 parts vendor thread for more info. Been doing a lot of reseach on the True Trac as it seems to be high respected in the LSD market. Anyone have any off road experiences with it yet? Good or bad?
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 07-22-2007, 10:34 AM   #2 (permalink)
SOCALTITANKC4X4LE's Avatar
Re: True Trac discount
Definately better traction on and off the road.
Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 07-22-2007, 07:02 PM   #3 (permalink)
TYTAIN's Avatar
No one with off-road experiences, such as one wheel spin out while crossing deep ruts? Just needing info to see how it will perform. It would appear most people are using them for drag time improvements.
PRG Shackles
Old 08-02-2007, 02:16 PM   #4 (permalink)
Diffs like this are great until one wheel has zero traction, usually when it is in the air. If you have the electronic system that will apply the brake to the suspended wheel and tire, then power will be sent to the wheel on the ground and you can keep moving, If you don't have the system and you have a wheel in the air you have to apply enough brake yourself to get power to the wheel on the ground. It's not as effective (because you are at cross purposes with gas and brake) but it works if you apply the right amount of brake.
I think driver's of early Humvees had to learn do this as they had Torsen differentials. Later versions had the ability to apply the brake to the suspended wheel. This is not based on real life experience as I haven't driven these puppies.
DavidC is offline   Reply With Quote
Old 08-06-2007, 11:17 PM   #5 (permalink)
baseballfanz's Avatar
The truetrac should not effect your ABLS.
Here's the first member to ever have a truetrac on a titan.
Truetrac in Titan - Review
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 08-07-2007, 12:20 AM   #6 (permalink)
NorCal 4x4's Avatar
I think his point was the ABLS is a good thing to have if you get the True-Trac ... TT needs a little resistance to engage. No ABLS, and you will have to use your brakes/parking brake or you'll just spin in some circumstances.
Old 08-10-2007, 10:18 PM   #7 (permalink)
Z-Hauler's Avatar
but then again, once you are in 4WD the front wheel should be able to pull you out enough to regain traction, right?
Z-Hauler is offline   Reply With Quote
Old 08-11-2007, 01:29 AM   #8 (permalink)
Fox Delta's Avatar
not necessarily -
if you are crossing something like deep ruts and have a front tire with little or no traction. The front is an open diff. so the tire with the least traction gets the most power!! We buy 4X4 to get two wheel drive
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
33x12.50/17 Mickey Thompson MTZon Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 08-11-2007, 01:31 AM   #9 (permalink)
Fox Delta's Avatar
is the TruTrac the only one avail for the Titan - I would love to get a Detroit locker. Our CUCV's had them and they worked great!
2004 XE 4x4 CC OR
Old 08-11-2007, 05:59 AM   #10 (permalink)
DawgBone's Avatar
Yes, the TrueTrac is the only one available. Fox, you have a PM...
Old: '04 SE Crew 4x2
New: '08 SE Crew 4x2
Nov 16, 1996, UGA at Auburn, 1st quarter: UGA V almost takes Auburn wide receiver Rober Baker's manhood off for catching a touchdown pass to put Auburn up 7-0. Stupid leash.
DawgBone is offline   Reply With Quote
Old 08-11-2007, 07:50 AM   #11 (permalink)
Fox Delta's Avatar
got the PM -- thanks for the good info!!
2004 XE 4x4 CC OR
Old 08-11-2007, 08:46 AM   #12 (permalink)
DawgBone's Avatar
Anytime, man.
Old 08-11-2007, 11:30 PM   #13 (permalink)
dbolemiss's Avatar
Send a message via Yahoo to dbolemiss
Just got my true trac installed.Do it,you cant go wrong.
dbolemiss is offline   Reply With Quote
Old 08-15-2007, 01:04 PM   #14 (permalink)
Titan671's Avatar
Send a message via Yahoo to Titan671
I took my 04 to the dealer after experiencing a tapping noise coming from the right rearend. The dealer checked and could not find the source. Their solution was to order a new rearend. I've read about trutrack and how many of the members love it. The only place I've checked was at Summit and boy...what a price! For those who have tru track, what other parts are needed for the install. Do you need to replace the differential cover?
Thanks.
2004 CCB LE w/ tow package
UpRev and Osiris tuned with supports from Chris and Randy and the member of TT and CT.
Titan671 is offline   Reply With Quote
Old 08-15-2007, 01:15 PM   #15 (permalink)
DawgBone's Avatar
Thanks.
If they're replacing your axle assembly, it will come with an updated vented differential cover, so you wouldn't need another one.
You have a P.M...
True Trac Lady Nissan 4x4parts.com 34 12-15-2007 01:59 AM
true trac etalian2005 Titan Performance Modifications 22 12-27-2006 08:32 AM
To those with the Detroit True-Trac Mychael101 Titan Performance Modifications 2 10-30-2006 07:20 PM
True Trac and Gears 04RamHemi Titan Performance Modifications 29 06-20-2006 08:41 AM
True Trac review kartman Titan Performance Modifications 12 06-18-2006 06:05 PM
