Old 11-19-2007, 08:32 AM   #16 (permalink)
jiggadog's Avatar
Re: Help on replacing drive belt?
Originally Posted by Mustard
Just changed mine, its real simple but not much room to work.
I used a socket wrench with a cheater handle for leverage.
As you loosen the tension you will notice that two holes on the tensioner start to move in line with each other. I cranked on it until they lined up and inserted a 5mm Allen into the hole, this will lock the tensioner into the released postion allowing you to focus on removing the old belt and installing the new. Once the new belt is in position just apply pressure to remove the Allen and release the tensioner.
replacing mine today and needed some help..perfect. i love this site...lol.
jiggadog is offline   Reply With Quote
Old 09-27-2008, 09:52 AM   #17 (permalink)
So are you saying that you placed a socket w/ the cheater bar on the bolt on the front of the tensioner pulley and then lifted up or pushed down?
Fieldworks is offline   Reply With Quote
Old 09-27-2008, 11:16 AM   #18 (permalink)
sudden urge's Avatar
I just changed mine a few weeks ago. I used a 1/2" drive ratchet and socket to release the tensioner and a 1/8" allen wrench to hold it in the released position. Facing the engine, you push the ratchet to the left (counter clockwise) to release the tensioner.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune +2 timing. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
??? on replacing p.c. coilovers.... rookieTITAN Titan Suspension 4 05-25-2006 11:03 PM
Need to replace Engine Drive belt ? talklessridemore Titan General Discussion 7 05-01-2006 10:56 AM
Replacing Radiator phillipyang Titan General Discussion 6 07-22-2005 08:17 PM
replacing handles Skip Hess Titan General Discussion 5 12-20-2004 08:46 PM
Removing and replacing... jusris Titan Interior Discussion 9 06-09-2004 12:38 AM
