Thanks Joker 19. I just got mine back today, they changed the whole rear axle. Had the tranny and fuel injection done while in there. Premiere Nissan was more than helpful, gave me a rental car and also notified me of a recall on the condenser fan motor. A big thumbs up for that Dealership.
I Have 73,300 on my Titan, Happy with the truck never had a problem but my rear end took a dump on me and I have to pay out of pocket. They want $4300. for the work which is bullsh''t. I want to rebuild it myself with high performance parts but I'm having a hard time finding vendors, am I going to have to swap the whole rear? Who can guide me if I would of known that they were not going to warranty it I would of not let them even touch it.
Go online and search. I have found new diffs for around $1500. Have it shipped to your mechanic to install. Prob do the whole job for less than $2500.
Nfabworks Home is who you want to talk to. He and his crew have been working with Trevor at WTO to get the rearend swap a reality for us. Give em a call.
__________________ 07 Titan Crew Cab LE 4X4 - Galaxy Black
Borla Titanium Exhaust;
Injen Power Flow CAI
PowerAid Throttle body Spacer
JBA Titanium Headers
UNICHIP Programmer w/CAI & CAT/B (JUNK)
Just the axle?
Getting the axle out is "easy."
The hardest part is being patient enough to break the seal to release the axle.
I used a mason's hammer (it's just a big heavy hammer) to do that.
Open the differential cover. On the bottom of the differential itself is a pin. Use a drift pin to get it out, and if I remember correctly, the axle should release.
Then just put it back together the way you found it. And maybe use the synthetic differential fluid they recommend nowadays.
most likly what happened was dana was going broke already and nissan came to them for an axle and dana said hey nissan will pay good money cuz japs actually care about the products so let charge them a but loads and make it as cheap as we can and maximize our profits.
who made the tundras rear? they dont have problems.
my 350z has a bullet proof rear i beat the pi$$ out of it driftin burnouts stock rear
...Uh that is in-correct....
After removing the 4 nuts behind the backing plate(and of course all the brake stuff...) the axle will come out with a slide hamer and adapter plate bolted to the axle flange...
PRG Performance Kit w/SAW's
Born 9/2004
My diff with 21K on it, its a 08.
I wash my truck one a week, and I went to spray the under carrige and found a mess on my hands. F**king pinion seal!
08 KC BT XE
MODS...
AID BOX MOD
K&N DROP IN
BANKS MONSTER
5100 BILSTIENS
ORI FRONT BUMPER
EDDIE FONZARELI GRILLE
3 HELLA RALLY 4000'S
ORI REAR BUMPER
CUSTOM CUT BEDSIDES
TOYO A/T 275/70/18
Has anyone questioned Dana about the problems with our front axles? Seals going out,shafts not seated,shafts popping out and other issues I didn't mention? Seems like they dropped the ball front and rear. And from the first post response from Dana sounds like they knew that these problems were eminent and still supplied them? This is no big deal to the folks in warranty, but when your out you are looking at a chunk of change. The after market loves are trucks as much or more than we do. What happened to the quality of the 21st century? JDK??
