Old 11-08-2007, 05:09 AM   #31 (permalink)
Re: motor noise sounds like lifter tick
once in a while if I run my 04 hard it will drop pressure just a hair below halfway when I am sitting still in drive but goes back to normal if in park or neutral.
bigkato is offline   Reply With Quote
Old 11-12-2007, 03:19 PM   #32 (permalink)
guls's Avatar
I've a 08 with 450 miles and I hear the ticking noise only in the morning and once it warms up it goes away. It is definately on the top of the motor. I took it in and dealer said it is normal.
My 2005 Kia Sorento did the same- dealer said it was normal.
guls is offline   Reply With Quote
Old 11-12-2007, 03:27 PM   #33 (permalink)
My 04 also has a very noticeable tick. Had it since day one, it’s got about 30k on it now.
I just ignore it and 99% of the time I don’t even notice it. I dose sound a lot like a lifter that is a little sloppy. But I think it’s just the normal valve train noise for the 5.6 endurance engine.
I have head some say it’s a bad ground but I duno.
lowlypawn is offline   Reply With Quote
Old 11-12-2007, 03:48 PM   #34 (permalink)
Yahooligan's Avatar
I have the same/a similar noise, seems to be coming from the driver's side and I can only really hear it or notice it at idle. Tick...tick...tick...about once every .5-.7 seconds. I figure it's probably an injector, but could be the evap purge valve (TSB for it). I'll bring it up when I drop it off for service on Wednesday. Doubt it's a big problem, it's just annoying.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
Motor Noise Deepwater Titan General Discussion 14 04-09-2008 06:28 PM
V-8 Lifter Noise jcdoyle Pacific Northwest Forum 3 02-22-2007 09:01 AM
Lifter noise on startup titanwild Titan Engine, Transmission & Drivetrain 16 03-10-2006 08:11 PM
Wiper motor noise with cold temps (-25 F) Treebasher Titan General Discussion 3 12-20-2004 08:12 PM
Electric Motor Noise? Bayou Titan Titan General Discussion 4 02-13-2004 02:00 PM
