Old 12-04-2007, 03:55 PM   #1 (permalink)
Shudder when leaving from a stop
I have a pretty hard shudder in the drivetrain when leaving from a stop. Generally shudders 2 or 3 times then is fine. If you slowly ease into the gas it is fine but in most cases it shudders. It is far worse with any load behind it or much weight in the box.
I am thinking it has to be torque convereter issues. It is fine once you are moving, like if you pull out to pass someone it is perfecty ok, no shudder, only from a stop.
Anybody else ever have this problem?
04 Galaxy Black CC, OR, BT, 127K miles and adding 150 a day to it!
03 Silver Murano SL AWD, Fully Loaded for the wife
95 Mustang GT Vert, Rio Red
95rioredvert is offline   Reply With Quote
Old 12-08-2007, 09:59 PM   #2 (permalink)
TallTexan's Avatar
Re: Shudder when leaving from a stop
Can also be universal joints. Pinion angle can also cause shuttering. Sometimes pulling a load or under heavy acceleration, the diff will bow up and cause the pinion angle to change so much that it can cause vibration. I have noticed it with my Titan pulling a trailer. If I had to enter the freeway in a hurry , I could feel the vibration but when I let of the gas, vibration stopped. Titans have weak springs and axle wrap is common. Once I installed the helper springs, most problems are solved.
Robert Louis Stevenson
Old 12-10-2007, 10:13 PM   #3 (permalink)
TitanTech659's Avatar
Have you flushed your trans fluid lately? If you haven't, that might help. We use BG products when doing our flushes where I work. One of the cans is specifically for torque shudder. I comes in a 2 can pack.
TitanTech659 is offline   Reply With Quote
Old 12-13-2007, 10:03 PM   #4 (permalink)
Send a message via AIM to BLOWBYU
I have similar issues. My truck off the line acts like a U joint is going out. But, I have taken the truck to the dealership 3 times for this. They replaced the rear end but that did not fix the issue. Here are list of things that have been checked:
U joint
transmission mount
motor mounts
Anyone else have similar issues?
This is driving me nuts.
04 Titan LE KC 4x2
Smoke
BT Mirrors
BT/hitch
Bought first week out! Boy am I dumb!
BLOWBYU is offline   Reply With Quote
Old 12-14-2007, 06:20 PM   #5 (permalink)
Thanks for all the opinions. I too thought of u-joints at first, had them replaced a while back and to no avail.
Going to have the tranny flushed and refilled in a few days. Hopefully it will help.
I find it odd that it only does it when leaving from a dead stop. That is what leads me to the torque converter idea, almost acts like it does not lock-up properly. I have absolutely no other vibrations at all. After you get moving the truck drives and feels great.
I let you know if the tranny flush helps.
Thanks again!!
Old 12-14-2007, 07:28 PM   #6 (permalink)
RB's Titan's Avatar
Try making these plates and shiming the carrier bearing. Home Depot carries the metal. I'd start with 3 thick and see if it gets better add until it stops if you get over 7 stop cause your likely not fixing the pinion angle and it's something else.
shudder-when-leaving-stop-shim-sml.jpg  shudder-when-leaving-stop-carrier-sml.jpg
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 12-15-2007, 06:53 PM   #7 (permalink)
No thats a great idea! and my kind of style, cheap and easy to try!!! Thanks again for the ideas!
Old 12-15-2007, 07:27 PM   #8 (permalink)
RB's Titan's Avatar
Your welcome also try the $22 Helper Spring Mod. All just easy bolt on stuff. Good luck and lets us know what happens would ya. One day I might need to know once I get those miles on her.
Randy
Old 12-19-2007, 01:01 AM   #9 (permalink)
many companys sell the carrier bearing spacer that will help a little but traction bars will solve the problem. Is there any lift on your truck? Theres nothing wrong with your trans>>>
nbk9nbk is offline   Reply With Quote
Old 12-19-2007, 07:57 PM   #10 (permalink)
Nope, no lift on the truck. Haven't had the trans looked at yet. Thought I would try the cheap springs first. Got them on today, they seemed to help a little, give it a shot with the trailer on it tommorow. Trans seems to work properly otherwise, probably end up with traction bars in the near future!
Old 12-19-2007, 08:57 PM   #11 (permalink)
Yahooligan's Avatar
I experienced this with my truck while towing a 23' tow hauler, only happened from a stop. Can't blame ujoints, trans fluid, etc since the truck only had 1700 miles or so on it at the time. It's not axle wrap either, definitely felt like something in the trans.
Also, it wasn't immediately after starting from a stop, as in starts at 0mph and stops at 15mph, more like it would start at 5mph and stop at 10mph. Not violent at all. Pretty weird, but shrugged it off as just the way it is. 17,000 miles and no problems.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
Old 12-19-2007, 10:37 PM   #12 (permalink)
AF-Medic's Avatar
Check your motor mounts. I doubt that it's the problem but you never know. I broke one in my chevy and it would shutter only while taking off or backing up.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
AF-Medic is offline   Reply With Quote
Old 12-20-2007, 04:37 PM   #13 (permalink)
Well towed the work trailer about 150 miles, lots of stopping and starting. The helpers did seem to help alot. only does it when starting out on a hill now, but not as bad as it was. Starting on level ground is greatly improved!
Have to wait a few weeks and then try traction bars also. Hopefully they will take over where the helpers are leaving off!
Old 12-20-2007, 06:34 PM   #14 (permalink)
http://www.jcwhitney.com/autoparts/P...008403/c-10614
These work even better
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 12-21-2007, 05:24 AM   #15 (permalink)
Originally Posted by Herbpov
Those do look nice, did they change your ride quality at all? I wouldn't mind a bit stiffer ride really. Thanks for the link.
Leaving Work Early mrgrim420 Off-Topic Discussion 2 10-12-2007 07:00 PM
leaving a trail behind you! Tiburon65 Titan General Discussion 2 12-02-2005 05:02 PM
Rv Trip, Leaving This Weekend tillery444 Off-Topic Discussion 0 07-28-2005 09:27 AM
Leaving the Titan for a year Chief Titan General Discussion 26 05-28-2005 08:38 AM
Kit for leaving low and high beems on together Treebasher Titan General Discussion 6 10-07-2004 06:29 AM
