Shifting vibration - Nissan Titan Forum
Old 01-27-2008, 12:32 PM   #1 (permalink)
pedalhappy1053's Avatar
iTrader Score: 0 reviews
Send a message via MSN to pedalhappy1053
Shifting vibration
When I shift from my first gear to my second, my truck shakes or vibrates. I think its the axle but I got no idea. Anyone else had the same problem?
pedalhappy1053 is offline   Reply With Quote
Advertisement
Old 01-28-2008, 08:29 PM   #2 (permalink)
mudfinder's Avatar
Re: Shifting vibration
Hey, I got the same thing that is happening to my truck but it does it between second and third and only if i'm accelerating hard. mines been doing it for about a year now. it's not getting worse or better. how long have you noticed yours? do you have any kind of lift on it? i've taken it to tranny shops. all say it's not the tranny. it's from the drivetrain. axle wrap, bad u joint, shims may need to be added, etc. let me know if you find anything,
05' Nissan Titan SE CC 4x2
SE Popular Captains Package
Rockford Fosgate
NISMO CAI
JBA Catback Exhaust W/ Banks muffler
DR Coilovers / PRG 1" Rear Lift Block
325/60R18 Nitto TerraGrapplers
305+HP and 379+lbs per ft of BALLS
mudfinder is offline   Reply With Quote
Old 01-30-2008, 07:28 PM   #3 (permalink)
1bigwhitetruck's Avatar
I had the same thing in my 07 titan, felt like driving down a washboard when it upshifted 2nd-3rd and banged when manually downshifted 3rd-2nd. Took it to the dealer and they put a diff, t-case, drive line. Finally had the trans replaced and the vibration went away. Had to go back cause they forgot to install the front driveline, But no vibration. May not be the cause of your vibration, but was the cause of mine.
2007 Nissan Titan CC 4x4 LE, -Daily Driver. Nismo CAI, PowerAid tb spacer, 2 degree advance, 2" Ready lift front kit 1" rear blocks, 35x12.50r18 Toyo open country m/t.
2005 Nissan Titan KC 4x4 Off-Road, -Not so daily driver. Stillen supercharger (3rd motor currently broken), AEM CAI, Custom tb spacer, 2 degree advance, Jba Headers, No cats, 3" straight pipe, 5" RBP tips, true dual exhaust, Pro-comp 6" stage 1 lift, Daystar 2" spacers, 3" custom body lift, Custom rear springs, Modified dana 60 rear axle w/4.88 gears, Modified front GM diff w/4.88 gears, 38.5x12.50r18 Pro-Comp Xterrain. Bare foot gas pedal (one day I will actually fix it and be able to drive it again)
1bigwhitetruck is offline   Reply With Quote
Old 02-01-2008, 08:05 PM   #4 (permalink)
I got a 6" PC lift on my truck, im still not sure what the vibration might be. Mine has been doing it for about a month. The dealer told me it was normal and that they didnt see any problems with it. I think they are wrong. What you guys think?
Old 02-05-2008, 01:05 PM   #5 (permalink)
mudfinder's Avatar
from the time you noticed till now, is it getting worse?? I checked my tranny fluid and it was kind of low. I added a little bit of tranny oil. It still does it, but not as worse. like i mentioned earlier, mines been doing it for about a year now. when i took my truck in to the dealer when i first noticed it, they said it's from the lift ( i have a 1inch block in the rear). i'm not worried about it. if it was a tranny issue, i'm sure i would of known by now.
Rockford Fosgate
NISMO CAI
Old 02-05-2008, 04:37 PM   #6 (permalink)
Mine is getting worse. Its doing it through all the gears, up and down.
Old 02-06-2008, 10:36 PM   #7 (permalink)
mudfinder's Avatar
One word for you...DEALER
good luck
Rockford Fosgate
NISMO CAI
Old 02-07-2008, 04:07 AM   #8 (permalink)
iTrader Score: 4 reviews
When I lifted my truck and added 35" wheels, I noticed a difference when it shifts. I think its normal since its shifting at the wrong shift points, which causes it to lag a bit. It makes sense, and I think your dealer is right-- not really an issue.
HOWEVER, if you add a CAI, like the K&N 77-6012, the small increase in power is just enough to make this problem disappear. But... I just saw your profile and you have a K&N intake... hmmm Have you cleaned your air filter recently, maybe its bad gas, dirty fuel injection, I don't know... maybe I am confusing your "vibration" with a slight loss or lag in power when it sometimes shifts... I don't get any serious vibrations. I'm still waiting to install my K&N, but I know it will solve my issue.
Energizer is offline   Reply With Quote
Old 02-07-2008, 11:38 AM   #9 (permalink)
I clean my K&N every time I changed my oil (every 3k miles). i always use premium gas so i dont think the injectors are dirty. It feels like a tranny or axle problem to me. The dealer keeps telling me its normal, i dont think it is.
Advertisement
Vibration when shifting mudfinder Titan Engine, Transmission & Drivetrain 0 01-12-2008 02:07 AM
Low speed Vibration and Hard shifting under accel Still thinkin Titan Engine, Transmission & Drivetrain 0 10-16-2006 10:24 AM
SEO by vBSEO 3.3.2
