Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Replacing Rear Axle Seal? - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 05-01-2008, 08:42 AM   #16
TallTexan
TallTexan's Avatar
Re: Replacing Rear Axle Seal?
If I was going to spend any money on a stock diff, I would install TruTrac at the same time. Might as well fix both problems at the same time. I see a complete new axle can be bought for around $1200 for non locking axle. If I am going to spend 500 dollars for a fix I know will return, I will go for a complete fix.
Robert Louis Stevenson
Old 05-01-2008, 08:48 AM   #17
54warrior
54warrior's Avatar
Originally Posted by prelude1911
so basically the seal that bad is where the whole axle slide into the housing? I want to try to do this myself but don't know how difficult it going to be to remove the whole axle. anyone know what involved in replacing the seal?
While I haven't done it...this is how I think it's done???
Remove the wheel/tire assembly.
Remove brake caliper/rotor/etc.
Remove four bolts/retainer plate which hold the axle/bearing/seal.
Slide axle out.
Destroy seal/bearing to remove.
Install new axle/bearing/seal assembly "kit" (How much of a PITA this is, IDK??)
Re-install the four bolts/plate.
Re-install braking system.
Re-install wheel/tire assembly.
Install Axle Vent Mod
Top off diff fluid.
Someone correct if that is wrong somewhere.
If you think health care is expensive now, wait until you see what it costs when it's free!
- P.J. O'Rourke
"The American Indians found out what happens when you don't control immigration"
Old 05-01-2008, 09:24 AM   #18
boya544
boya544's Avatar
Slide axle out.
Top off diff fluid.
There is a collar that is pressed on that holds the bearing. That has to be broken off before you can slide the bearing and seal off. The new collar will come with the seal and will have to be pressed back on to the axle. If your going to do it yourself I would replace the bearing also just for peace of mind. So you wont have to do it again for the bearing. And yes definately do the axle vent mod.My right rear axle had a little seepage and after I did the vent mod it seem to stop. My backing plate is still dry after I had wiped it off. I think my vent must have been plugged causing pressure to build up and forcing the oil out the seal. because now after 7k mi. Its still dry.
_________________________________
05 CC 4x2 Red Alert
20" VCT Scarface Rims
Injen CAI
Volant Stainless Exhaust
2* Timing Adv.
boya544 is offline   Reply With Quote
Old 05-01-2008, 06:54 PM   #19
TitanTech659
TitanTech659's Avatar
It's a lot easier if you have a press to get the bearing off. The bearing will get destroyed and will need replaced.
TitanTech659 is online now   Reply With Quote
Old 05-03-2008, 10:27 AM   #20
prelude1911
so the only parts i need to order from the dealer is the axle seal and the new bearing correct?
Here the P/N and price I got from the dealer.
Axle Seal P/N 43252-7S200 $38.15
Bearing P/N 40210-7S210 $75.44
Anything else?
prelude1911 is offline   Reply With Quote
Old 05-04-2008, 10:10 PM   #21
TitanTech659
No, you'll need the collar and the plate that has the studs on it as well.
Old 05-05-2008, 07:06 AM   #22
Wiscdave
Wiscdave's Avatar
On my old 04 I had the dealer do 4 seals before 62k...I wanted a new rearend on the 2nd one at 30k Something must have been wrong to blow 4 right? Well now they didn't fix the rear end and I decided to sell the truck because of it causing the seals to fail every 15k. Too bad Nissan can't stand by their products and just let their customers get screwed. And you wonder why people won't buy the titan again.
04 XE CC 4x4 traded at 62k for 08 4x4 Taco LB DC TRD sport
Wiscdave is offline   Reply With Quote
Old 05-10-2008, 07:34 PM   #23
prelude1911
anyone know where i can download a free copy of the service manual so i can try to attempt this repair myself?
Old 05-11-2008, 08:38 AM   #24
Easy E
I picked up a CD-ROM manual off eBay. It's very detailed and worth the measly $10. Just a cheap copy on a disk though...
I can't post links yet, but it's Item number: 190220600397 (go to eBay.com and type in the item number in the search bar)
Easy E is offline   Reply With Quote
User Name
Password
rear axle seal nytitan1 Titan Engine, Transmission & Drivetrain 35 10-01-2007 10:15 PM
Rear axle seal and rear diff inspection Smoke05 Titan General Discussion 8 09-26-2007 01:21 PM
replacing rear axle Titansg1 Titan Suspension 13 07-22-2006 12:11 AM
Rear Axle Seal Leaking?? JimB Titan General Discussion 15 10-11-2005 06:50 PM
nissan replacing brakes/rear axle seal bbplayajs Titan Problems & Dealer Service 2 06-14-2005 02:42 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
