Re: TRUETRAC Mag-Hytech Diff Cover AND 3:73 GEARS
So if I buy a factory e-lock diff, can I install it in my 2WD Titan's rear axle housing? If so, how in the hell do I lock it? Do I have to run wires and all that garbage? And, are the spline counts the same for 2WD or 4WD? I found some Big Tow gears (the whole carrier assembly) e-locking for $600 and I can swap it out myself, quite easily as a matter of fact.
Yes it should all work, but you will have to wire it up...and all that garbarge...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
