Old 03-21-2008, 10:47 PM   #106 (permalink)
BECHLYF's Avatar
Re: TRUETRAC Mag-Hytech Diff Cover AND 3:73 GEARS
Originally Posted by bigtit
I had 3.73 put in about last July and i also swapped in the factory e-lock diff. The gearing change is not as noticeable as you would think. But the nissan service guy who drove my truck said it was the quickest titan he has driven. IMO it is well worth $550 bucks, hell i paid way more than that and i have no complaints. And the e-locker is priceless in a 2wd, if you have the chance to grab one, get it.
I think whether it is more or less noticeable depends on what ratio you start with BT 3.36 or non BT 2.94. I had the non BT 2.94 and I can really tell especially when I'm getting WOT After 40MPH. After I get a UpRev tune I will get WOT from 0 MPH and more HP and TQ through out the power band THEN it will REALLY PULL like a MUTHA! FROM 0 MPH!
SEE WHAT UPREV CAN DO FOR YOU! CLICK IT MAN!
Old 03-21-2008, 10:57 PM   #107 (permalink)
pgthe1's Avatar
BECHLYF... nice meeting you today... thanks for the ride also lol. Did you get that tire psi down... I could feel that the tires had at least 38#'s in them lower it down a little bit and it will feel plush unless you like the tight feel from the tires. see you in the dirt
pgthe1 is offline   Reply With Quote
Old 03-22-2008, 11:55 PM   #108 (permalink)
I only really drive around town but my gas mileage is horrible. 8.6 mpg on average. I have a bit of a heavy foot though.
2007 c/c Cst Spindles, TCA, SAWs, Deavers, Bilsteins, and the only (that i know of) regeared titan sporting 3:73's in the factory axle
bigtit is offline   Reply With Quote
Old 03-26-2008, 06:02 PM   #109 (permalink)
pgthe1's Avatar
Just spoke with Anthony at Hooper's .... said they just finished another Titan yesterday who was it lol... Mine is going in on Friday... No gears just TT getting installed.
Old 03-26-2008, 09:43 PM   #110 (permalink)
hooligan's Avatar
no gears? is that because you already have the big tow gears, pg?
Old 03-26-2008, 09:44 PM   #111 (permalink)
BECHLYF's Avatar
Dude, get the gears, my truck feel better at all speeds and who needs cruise control anyway
Old 03-26-2008, 09:50 PM   #112 (permalink)
hooligan's Avatar
yeah, but if he's got big tow gears, he's pro'ly thinking 3.36s ain't too bad. but f*(k... i need them since i only have 2.94s
Old 03-26-2008, 10:08 PM   #113 (permalink)
pgthe1's Avatar
Yeah I have the BT gears... I was going to get the gears, but I saw the size of the Pinion on the those 3:73 looks a little small for my taste. It maybe okay... but If I was able to shear one in half with the 3:36's... I don't want to chance it. I'll just get the UpRev for some power.
Old 03-26-2008, 10:16 PM   #114 (permalink)
BECHLYF's Avatar
I just went on Precision Gear Calculator and pgthe1 will gain around 207.20 RPM if he has big tow gears and 36's and I gained around 468.42 RPM in 5th gear doing 75 MPH with 35's because I have (HAD) the same gear set as you. Hoolie, your gonna love it. Now that I have had a chance to drive the truck I notice more power and in 1st-5th the truck is not straining to accelerate. And even though I have had to have will power to keep off the gas I think I'm getting better gas mileage. Much MORE responsive thats the word RESPONSIVE. all around more fun to drive, now if I could swing UpRev Wooooooooooooosh. the truck WILL become a bat outta HELL! WOT from 0 more HP & TQ
Old 03-26-2008, 10:21 PM   #115 (permalink)
BECHLYF's Avatar
Hi Pete, the gears Hoopers installs are not the same, they are Super 44 Dana/Spicer the same type that are used in the Viper. and 200 RPM more wont hurt. and one of the reasons your pinion broke might have been that your gearing was not low enough, if you put a load on it and its not as easy to turn something is gonna give. so if you change the gears they will be stronger and they will turn the tires easier. less strain (force, energy) to turn the mass. HEY! is that physics?
Old 03-28-2008, 10:32 PM   #116 (permalink)
Hawaiianbasshead's Avatar
Re: HOOPER'S / TRUETRAC Mag-Hytech Diff Cover AND 3:73 GEARS
The area is not that bad, it is a area full of wrecking yards and a big rig car wash. I walked down the street to get a bite to eat, there was a roach coach that stayed parked down the street. and look at what was across the street from the coach.
lmfao, even before I clicked the pix I kinda thought strip club when I read across the street, for some reason that's the 1st thing that came to mind
Old 03-31-2008, 08:54 PM   #117 (permalink)
Any of you Hooper gear swap guys still have your 3.36 gears layin' around? If so please PM. Thanks.
OregonX is offline   Reply With Quote
Old 04-01-2008, 02:52 PM   #118 (permalink)
Has any one done the gears in both the front and the rear? What happens when your in 4x4 mode with two gear ratios front and rear? Does anything have to be done with the ecu after you make the gear swap? Thanks for the info.
aznissan is offline   Reply With Quote
Old 04-01-2008, 03:57 PM   #119 (permalink)
BECHLYF's Avatar
Not to my knowledge,BAD THINGS they have to match,No but you lose cruise control. 4X4 ?
Old 04-01-2008, 05:25 PM   #120 (permalink)
So guys doing this mod are either 4x2 or never will use 4x4? I wonder if hoopers can do the front gears to match? Does anyone know?
Diff Cover titanss Titan General Discussion 20 11-02-2006 07:29 PM
Mag-Hytech Diff Cover. FINALLY!! Nissanloyalist Titan Engine, Transmission & Drivetrain 20 06-13-2006 08:21 PM
Mag-Hytech...Rear Dif Cure Or Minor Help? Jinkster Titan General Discussion 10 06-09-2006 07:33 AM
04 had rusted diff cover dealer put updated cover on Aquaholic Titan General Discussion 11 03-18-2006 09:41 AM
