Old 05-19-2008, 12:11 AM   #1 (permalink)
Seeping after vent mod
Quick info about my rear end: Had dealer put in new seals on both sides of the axle on 11/13/07 at around 47,800 miles due to seals appearing to seep out. Once the truck hit 50k miles, there were signs of seepage returning. I just recently did the vent axle mod on 5/10/08 at 55,281k miles, and now at 56k miles, it's starting to show a more progressive seepage. There are seepage showing around the toyota breather adapter and both sides of axle. I dont have my camera usb line anymore so i cant connect it to my comp. i can only save pics on my camera. wish i could take some shots. The nissan dealer that i brought in for my warranty repair work gave me some hard time because they said it was normal and couldnt do anything about the seals seepin blah blah... Is there anything else i could do or should i just wait til it starts leaking til i bring it in? Any advice is appreciated.
2006 Titan SE CrewCab 4X2 Smoke, SE Popular Package, StepRails
upshift is offline   Reply With Quote
Old 05-19-2008, 10:41 AM   #2 (permalink)
Re: Seeping after vent mod
Well after I did my mod I did have one start to seep, but I cleaned it off and kept an eye on it. And then it later stoppped. So I would keep an eye on it, and if it continues then I would take it in.
x2thez is offline   Reply With Quote
Old 05-19-2008, 03:43 PM   #3 (permalink)
Thank you for the quick reply, ok i will try to keep an eye on it.
Old 05-20-2008, 07:02 AM   #4 (permalink)
TallTexan's Avatar
Those seals should not leak, period. Before your 60k warranty runs out, go back to dealer and tell them to fix it. You might get a new diff out of it. Get a little upset that the diff is leaking again and yhour warranty is running out. You may want to put your little factory vent back before you take it in. Don't give them any excuses.
Robert Louis Stevenson
Old 05-20-2008, 07:23 AM   #5 (permalink)
BK19702's Avatar
Your axle seals should not leak, so definitely take it back to the dealer and have them address it. Seepage around the OEM vent is not unusual, but there should be no seepage from the seals. Good luck!
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
Old 05-22-2008, 12:25 AM   #6 (permalink)
thanks for those ideas guys, i will bring it back to the dealership (a different one from before) before my warranty expires and see how it goes. I actually bought the factory extended warranty til 75k just fyi.
OEM Vent Visors mwippern Titan Parts & Accessories 3 10-20-2007 08:47 PM
Just need to vent Kwaz Titan Problems & Dealer Service 21 07-20-2007 10:38 AM
Seeping trans cooler hose clamps... loufish Titan Problems & Dealer Service 2 11-18-2005 09:29 AM
AVS Vent Shades Titantow4 Titan Parts & Accessories 1 02-18-2005 09:56 AM
Need To Vent!!!! emt293 Titan General Discussion 20 12-15-2004 10:51 AM
