Old 03-01-2008, 10:34 PM   #1 (permalink)
4WD - backing up
Twice now we've had enough snow to justify using 4WD. And both times, I've had 4WD HI engaged when I backed into my parking spot and both times, while backing up and turning, I've the front end seemed to bind up, pop, then the front wheels roll freely.
The description isn't exactly accurate because the sensation is hard to describe. But after the pop, the whole backing up motion seemed smooth.
I only have 2000 miles on my 08. This behavior normal? During the motion, my wheel was turned as far to the right as possible.
gksmith is offline   Reply With Quote
Old 03-02-2008, 12:07 AM   #2 (permalink)
AF-Medic's Avatar
Re: 4WD - backing up
Totally normal. The front diff is chain driven. There will be some popping with it. Be careful with the wheel full lock with 4x4 engaged.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
AF-Medic is offline   Reply With Quote
Old 03-02-2008, 12:08 AM   #3 (permalink)
Sammy Sandbag's Avatar
Part-time 4WD vehicles will bind (eventually break) when 4WD is engaged and making turns on surfaces with enough traction to not allow the wheels to slip. What you are experiencing is not good and could lead to potential driveline damage. Do yourself a favor and disengage 4WD when you need to make turns.
-Counsel Yourself
Old 03-02-2008, 12:47 AM   #4 (permalink)
Kooshtaka's Avatar
Yeah this will happen not only when backing up but driving forward if you have your wheel fully cranked over. should go away just as long as you don't fully crank. AF and Sammy have given the mechanical reasons.
2005 Nissan Titan
Crew Cab
SE, 4x4, OR, BT, Utility
Mods: Bullbar, Lights, Overhead Rack
Mods being planed: AEM Brute W/Banks and Stillen Headers, Lift from greg, tyres
Dubbed The Yellow Snow Whore
Kooshtaka is offline   Reply With Quote
Lug nuts backing out???? tcf_dk Titan General Discussion 11 12-06-2006 03:15 PM
Backing up in 4wd Biscuit'sTitan Titan General Discussion 7 05-31-2006 06:20 PM
Cracks When Backing Out Of Driveway MississippiTitan Titan Problems & Dealer Service 5 03-20-2006 12:54 PM
Brake Squeal when backing up? Taskmaxter Titan General Discussion 4 11-30-2005 03:34 PM
Brake noise when backing up chue Titan General Discussion 1 03-19-2005 12:32 PM
