Old 05-01-2008, 11:02 PM   #1 (permalink)
titaninak's Avatar
transmission flush or NOT!!!!! !??????????
ok, i just want some opinions on transmission flushes, good and bad.... does our truck really need it. etc.......
2006 LE, CC, BT, 4x4-Blizzard White
JBA catback, K&N cai, poweraid TBS, grounding kit, 2 degree timing, UpRev tuned <in progress, TruTrac
Debadged,4 piece billet grille, Diamond plate truck Box, 20"Akuza wheels, tech12's w/ Memphis PR1-1000 amp / M-10's, Kenwood 7019 DD,DVD HU, Line of Fire LED light bar, LED third brake light, ADJURE crystal eyes tails, EFX HID lows and fogs, painted to match MADA air dam / inchannel window visors, Stillen Billet aluminum cap covers, 15% front tint, Non BT mirror swap.
titaninak is offline   Reply With Quote
Old 05-02-2008, 03:49 PM   #2 (permalink)
TallTexan's Avatar
Re: transmission flush or NOT!!!!! !??????????
Not for me. I drained the pan and refilled. That is about it for me. My truck has 75k and trannie feels good.
Robert Louis Stevenson
Old 05-02-2008, 04:24 PM   #3 (permalink)
dawgs77's Avatar
Nissan says do not flush the Jatco tranny.....do a drain and fill only.
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
dawgs77 is offline   Reply With Quote
Old 05-02-2008, 06:26 PM   #4 (permalink)
titaninak's Avatar
keep them coming i know you real truck enthusiasts have an opinion on this, i am trying to brain storm what caused my tranny to fail and just want to cover all things that happend to my truck (including tranny flush) from delivery from dealer to 28,000mi.< tranny failed at this miles
Old 05-02-2008, 06:49 PM   #5 (permalink)
I had mine flushed at the stealership at 30,000(on my 06' XE CC). I mainly did it because it was given to me by the stealership for free because they screwed up on another service. I sold the truck with 36,000 on it and got a 08.5 SE CC, but didn't have problems with the trans before selling it. Normally I'm not big on these type of things or I try to do them myself, but apparently the stealership actually has a machine to vacuum all the fluid out and replace it. Apparently you don't get all the old fluid out by just draining it yourself. I will probably do it on the 08.5 just so the stealership doesnt give me a hard time if I need warranty work done after the 36,000 mile warranty. After that I'll probably wait a long time till I do it again. You can do a search and see what other guys do about this and there's some threads that talk about what guys here have paid for the service as well. Good Luck
nissan72 is offline   Reply With Quote
Old 05-02-2008, 07:04 PM   #6 (permalink)
tholmes's Avatar
I had 70k on mine before i had it done. Definitely made a difference.
If it's a penny for your thoughts, and you give me your two cents, what happens to the other penny? Taxes, the Democrats tax everything!
Robert Holmes
2005 Titan LE Crew Cab 4x4
Glacier White
Big Tow
RollBack Tonneau Cover
Aftermarket Nav
AVS Bug Shield
6000k HID Conversion
AEM Brute Force Dry Intake
Navone LOC NE-774V (http://www.davidnavone.com/cart.asp?14&pid=155)
Tech12Volt 12in Box
1 12in Boston Acoustics G1 Dual 4ohm Subwoofer
Rockford Fosgate P3001 Mono Amp (300watts rms x 1 at 2ohms, 150watts rms x 1 @ 4ohms)
tholmes is offline   Reply With Quote
Old 05-02-2008, 07:19 PM   #7 (permalink)
NorCal 4x4's Avatar
Not!
http://www.titantalk.com/forums/1208393-post5.html
NorCal 4x4 is online now   Reply With Quote
Old 05-02-2008, 07:45 PM   #8 (permalink)
Just-in's Avatar
yeah drain and fills only swap the fluid out in the pan, to get the fluid out of the torque converter you gotta do a flush with a machine like a t-tech.
Galaxy Black 07 LE
Old 05-02-2008, 08:07 PM   #9 (permalink)
NorCal 4x4's Avatar
No, flush without the machine like the service manual describes.
Old 05-03-2008, 06:05 PM   #10 (permalink)
37L1's Avatar
Originally Posted by NorCal 4x4
This is getting old.
http://www.titantalk.com/forums/1211673-post22.html
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 05-03-2008, 07:10 PM   #11 (permalink)
NorCal 4x4's Avatar
Originally Posted by 37L1
That's where I remembered seeing it posted, and since Titan Talk now allows posting links to Club Titan, I thought it was o.k. Sorry.
Old 05-03-2008, 08:34 PM   #12 (permalink)
Burgy's Avatar
Send a message via AIM to Burgy
I think it should be mentioned that there is a difference between POWER flushing and a simple flush. Chain shops will POWER flush a trans using fluid and possible cleaning agents. When my dealer did my Pathy they used a machine that simply reclaimed old fluid while returning new. The trans did the actual pumping, there was no additional stress on the system and now chemical cleaners added.
Trans worked perfectly with never an issue.
The method my dealer used is similar to what you could do in your own driveway.
Burgy
(Kevin)
08.5 Titan CC SE 4x4
Burgy is offline   Reply With Quote
DIY transmission FLUSH guys check in..... itssr20 Titan Engine, Transmission & Drivetrain 2 03-01-2008 11:24 PM
Transmission fluid drain vs. flush Skiff Fisher Titan Problems & Dealer Service 9 02-26-2008 12:39 PM
Flush PRJ Titan Engine, Transmission & Drivetrain 10 01-07-2008 08:02 AM
Transmission Flush / Fluid Questions faith+1 Titan Engine, Transmission & Drivetrain 20 03-27-2007 03:29 PM
Transmission Flush KYDeepwater Titan Engine, Transmission & Drivetrain 9 12-30-2006 06:43 PM
