Old 03-26-2008, 12:15 AM   #1 (permalink)
ckb
check engine light
I have a 2005 titan and get a lean mixture code. dealer says was because of k &n filtercharger . Have gone back to factor air filter and still get the same code. any ideas?
ckb is offline   Reply With Quote
Old 03-26-2008, 12:25 AM   #2 (permalink)
Schrute's Avatar
Re: check engine light
Dirty MAF sensor? Maybe some oil from the filter got on it?
08 LE 4x4. SAW C/Os (2.5" preload). PRG UCAs. PWM. No swaybar. SAW Piggybacks. Deaver C10 leaf pack (-big leaf). PRG Shackles (-1"). PRG OR T-Bars. AR Motto MT100 20x8.5 wheels. 35x12.50 Toyo M/Ts. AEM Brute Force. Nismo Duals. 2° Advance. AMP Steps. Hella 500 lights. ScanGuage II. Debadged.
Schrute is offline   Reply With Quote
Old 03-26-2008, 08:07 AM   #3 (permalink)
Shane06fl's Avatar
try some of that sensor cleaner and spray down the MAF real good. Some use brake cleaner ( I have before) but the sensor cleaner may be safer.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
P1027 Service Engine Soon Check engine light Hendge Titan General Discussion 0 01-21-2008 02:28 PM
Check engine light? Helinut1970 Titan General Discussion 10 05-31-2006 07:11 PM
First check engine light the head Titan Problems & Dealer Service 17 08-24-2005 06:39 AM
Check Engine Light argonaut1992 Titan Problems & Dealer Service 6 08-19-2004 06:42 PM
