Old 03-29-2008, 02:19 PM   #1 (permalink)
Coolant replacement??
Hit 12k finally in my 06. Nissan told me to just buy peak coolant. Any how to do's on this?? Want to know if there are any bleeding valves or anything else I should know before doing it myself??
Toyoda by heart....Nissan by mind. Volk TE37s on my 06 Armada. JBA Headers/K&N Exhuast/Afe fliter/Suncoast hood http://s182.photobucket.com/albums/x193/suprahajimoto/ http://profile.myspace.com/index.cfm...ndid=176853583
madahajimoto is offline   Reply With Quote
Old 03-30-2008, 02:22 PM   #2 (permalink)
Justintoxicated's Avatar
Re: Coolant replacement??
Only 12k? Why change it so soon?
Old 03-30-2008, 02:44 PM   #3 (permalink)
TitanBlue's Avatar
Nissan says change at 60K and then every 30K.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 03-30-2008, 02:52 PM   #4 (permalink)
I thoguht it was just every 30k and I thought you needed a flush machine to do it. Otherwise your only doing a partial change? I did mine at 40k I'm not sure how much difference this really makes.
Old 03-30-2008, 05:36 PM   #5 (permalink)
Oh man, I sware I read it was 12k or every two years. Man, thank gawd I havnt changed it yet then.
Old 03-30-2008, 06:13 PM   #6 (permalink)
TitanBlue's Avatar
I had just been reading the original 04 service manual today, and came across the info. Looks fairly typical.
Born June 12, 2006
Old 04-01-2008, 07:20 PM   #7 (permalink)
TitanTech659's Avatar
You dont NEED a machine to flush the coolant. Just take the radiator cap off and pull the drain plug. Then take off one of the heater hoses and run a garden hose into it. That will flush out the heater core and the block. You should see the color change from green to clear when it comes out of the drain plug. To fill the system clamp off the overflow hose and fill the radiator. Put the radiator cap on then fill up the tank. Let it run for a while (keeping it filled) untill the heater is consistantly hot. If the heater is cold at idle then you didnt get all the air out.
TitanTech659 is offline   Reply With Quote
Old 04-01-2008, 09:33 PM   #8 (permalink)
gabriel c.'s Avatar
what about the thermostat? might as well change that out too.
third coast titans
gabriel c. is offline   Reply With Quote
Old 04-06-2008, 09:43 PM   #9 (permalink)
Anybody got a electric fan yet??? I talked to Spal and they said they dont make one for the Titan or Mada, but they said to send the demensions and they will see what they have.
Old 05-08-2008, 08:31 PM   #10 (permalink)
gabriel c. what about the thermostat? might as well change that out too.
04-01-2008 09:33 PM
Don't you have to remove the water pump for that?
2004 Nissan Titan Galaxy Black King Cab SE
Street Scene Chrome Speed Grills, HID Headlights, Viper Alarm with Remote Start, Pioneer Navigation w/rear view camera, Bilstein 5100's Shocks on Front and Icons on the rear
stanzaboi is offline   Reply With Quote
Old 05-08-2008, 09:53 PM   #11 (permalink)
No you don't have to remove the water pump to get to the thermostat. You can replace the thermostat in about 1/2 hour.
Old 05-10-2008, 09:16 PM   #12 (permalink)
Ok, good. How do you change the thermostat? I'll go ahead and change it when I flush the radiator. Never worked on the Titan yet, so I'm kinda nervous. Thanks.
Old 05-11-2008, 01:41 AM   #13 (permalink)
AF-Medic's Avatar
I wouldn't use a garden hose. The water needs to be distilled or purified or you will get deposits and crap in the radiator.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
AF-Medic is offline   Reply With Quote
Old 05-11-2008, 05:50 AM   #14 (permalink)
TitanBlue's Avatar
I agree, but from the practical standpoint, how are we going to flush it with distilled water???
Most mechanic shops still use a hose to flush and fill. Really...
BRIGHT IDEAS:
1.) FLUSHING-A Filter that screws onto the hose Bib would be a good thing to do. Just thought of this. Pipe Thread to Bib adapters are readily available at any Hardware store. So a Filter with Pipe Threads could be adapted for this. Cost less than $25 I'd think...
2.) RECOVERY-Now, how about we recover the majority of that Antifreeze and recycle properly, instead of running it down the Storm Sewer which goes to the River. 2 or 3 Gallon jugs for the initial drain and beginning of the flush would be a good thing to do. Local dump has a place to dispose of Antifreeze. Part of the Saturday morning routine.
Using Filtered or Distilled Water for the mix is certainly easy to do, or buy Premixed Antifreeze.
Born June 12, 2006
engine coolant DrewShoaf Titan Engine, Transmission & Drivetrain 27 01-09-2008 07:59 AM
How much A/C coolant? Footloose301 Titan Problems & Dealer Service 4 11-11-2007 08:08 AM
What I thought was a coolant problem...was a coolant problem Harley Edition Titan Titan General Discussion 18 01-06-2007 07:14 PM
Anyone know the best way to drain coolant? doctor steve Titan Parts & Accessories 2 10-09-2005 07:04 PM
