Re: pinion seal leaking... again...
Probably pinion angle. Due to our weak spring setup, spring over axle, when you tow the axle twists upward putting a bind on the diff. Mine would make a hopping sound when pulling my trailer as the driveshaft compensated for the axle twist. Welcome to the club. I would install heavier springs or traction bars if you want to continue pulling.
Robert Louis Stevenson
