Re: worth it to put a finned diff cover?
Originally Posted by Derwud
That is the PML, the Stillen isn't as deep, and the Mag-Tech doesn't come in three different versions.
So I installed my PML cover this weekend and the extra quart of Mobil 1 should help. I want to add something I observed about the PML cover. The PML cover has a sump to it so that extra Qt stays at the bottom of diff where it belongs. With the Mag-Tech and the stock unit fluid may be pulled away from the gear set on accel. Plus with the larger fins above the sump it should also cool better than the other two... Just my opinion..
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). Stillen Grille, AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Air Box Mod and K&N drop in, Gibson Exhaust, PML Rear Diff Cover and Trans Pan. Towing WW FS2300 Toyhauler and all the toys.
The Rhino, The Titan, Truck and Trailer
I HIGHLY recommend PRG Products, SDR Motorsports, Desert Works Fabrication, Live Wire Whips, and Gibson Exhaust
