Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Help ASAP! - Dash Lights On After Car Wash - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 04-19-2008, 05:26 PM   #1
Dads_taxi
Dads_taxi's Avatar
Today, I was at the car wash and sprayed the engine compartment. I've done this before many times. But this time, when I started the engine it rev'ed up to 3k and idled very strangely. I was able to drive 1/2 mile to home where I disconnected the battery for 2 hours. After reconnecting, the Check Engine and SLP lights remained on. I drove the truck aound the block, but no thottle or power. This is not good.
I am disconnecting the battery and will let sit over night. Also, I have the VK-PRO. Any other suggestions???
Thanks in advance.
Dads_taxi is offline   Reply With Quote
Old 04-19-2008, 05:33 PM   #2
Seerex
Seerex's Avatar
Re: Help ASAP! - Dash Lights On After Car Wash
If you have canned air try drying some of the engine key aspects , check all fuses relays and connections. No throttle at all? Or just extremely low powe?
2005 SE Crew 4x2
Blizzard White
Tow/Trac/Popular/Utili-bed
Born 3-05
Taken Home 5-05
Seerex is offline   Reply With Quote
Old 04-19-2008, 05:37 PM   #3
Dads_taxi
Dads_taxi's Avatar
Just extremely low power.
Old 04-20-2008, 08:36 AM   #4
tim@mcintyreinsuranc
I had the exact same problem. After taking my truck to the dealer, I found out that the VK Pro connection was allowing water to short out the ECM (the dealer stated that there were signs of corrosion on the connection). The dealer removed the VK Pro and reset the ECM. It's fine now...
T Mac
tim@mcintyreinsuranc is offline   Reply With Quote
Old 04-20-2008, 02:46 PM   #5
Dads_taxi
Dads_taxi's Avatar
T Mac
I just took off the VK-PRO and found wet green corrosion. I cleaned everything thoroughly with electronics cleaner and Q-tips. I left the VK-PRO off and it is running better. The Check engine light remains on. I guess I'll have to take it in to the dealership this week.
Thanks
Old 04-20-2008, 07:21 PM   #6
Shane06fl
Shane06fl's Avatar
Don't know what the connections look like but a little dab of dielectric grease or battery terminal spray might help with corrosion.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 04-20-2008, 08:07 PM   #7
Dads_taxi
Dads_taxi's Avatar
I will try that later this week when I reconnect the VK-PRO.
Old 04-20-2008, 09:49 PM   #8
Justintoxicated
Justintoxicated's Avatar
Try to get the diagnostic reading. Theres a way to read the error code without taking the truck in, as well as reset the ecu / clear the check engine light . Just search the forum.
Old 04-21-2008, 08:33 PM   #9
Dads_taxi
Dads_taxi's Avatar
My check engine light went out after leaving the battery disconnected overnight. My plan is to get a ScanGauge when my wife will left me. Right now, she has veto power. I need to be a good boy a little longer before I ask.
Old 04-22-2008, 12:40 AM   #10
Justintoxicated
yea that would be nice, I want one hooked up to a car PC so when something happends I touch the screen and it tells me the problem lol. but its not going to happen so I use the pressing the break pedal trick to read codes and look up what they mean on the net.
User Name
Password
Red Dash lights, LED rjspitz Titan Interior Discussion 18 03-20-2008 11:29 PM
Dash lights out jonnylayne Titan General Discussion 2 11-09-2007 08:27 PM
Digital dash went screwy (odometer, gear indicator lights, 4X4 indicator lights) Treebasher Titan Problems & Dealer Service 4 05-07-2005 07:27 AM
dash lights Tex40 Titan General Discussion 2 02-14-2005 08:25 AM
dash lights Tex40 Titan General Discussion 1 02-13-2005 06:27 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
