Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Engine, Transmission.. HELP - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 05-05-2008, 09:01 AM   #16
Carbeaux
Carbeaux's Avatar
Re: Engine, Transmission.. HELP
Click image for larger version
See if this helps.
Hook 'Em Horns!
AKA TroubleWhore™
AKA HitAndMissWhore™
AKA SigPicNaziWhore™
“I Had the Right to Remain Silent...But I Didn't Have the Ability" - Ron "Tater Salad" White
Click here for a list of my mods
Click here to see my photo gallery
Old 05-05-2008, 09:38 AM   #17
Guiseppe
Guiseppe's Avatar
That was my next guess, so don't try to clean it. I have noticed something else. I also have an 04 Armada. When the truck is started and sits in park, it is running about 750-800rpms, my wifes armada runs closer to 550-600rpms in park. Could that be something? Generally the truck just seems to be downshifting at a lower rpm, maybe its in my head but that's what it seems like. Any ideas.
Guiseppe is offline   Reply With Quote
Old 05-05-2008, 09:40 AM   #18
walleeme
walleeme's Avatar
Does she have a vacuum leak somewhere?
Hear any hissing sounds while it's running?
My truck has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES.
walleeme is offline   Reply With Quote
Old 05-05-2008, 09:46 AM   #19
Guiseppe
Guiseppe's Avatar
Are you talking about my Titan or Armada, I hear no hissing, which RPMs sounds right, or is there not a right or wrong.
Old 05-05-2008, 09:54 AM   #20
Carbeaux
Carbeaux's Avatar
The ECU is different for the Armadas and Titans. It may just be a different set point for the two.
Old 05-05-2008, 10:06 AM   #21
Guiseppe
Guiseppe's Avatar
Alright, I will try some injector cleaner or something similar and then see what happens. If something is really bad wouldn't check engine light come on or something
Old 05-05-2008, 10:10 AM   #22
walleeme
walleeme's Avatar
The Titan.
Take a look, and listen a little.
It might be just a perished or disconnected hose near the intake.
Old 05-10-2008, 03:07 PM   #23
Guiseppe
Guiseppe's Avatar
Update:Re: Engine, Transmission.. HELP
Reset ECU, went through 2 tanks of gas and add engine/ fuel injector cleaner. Truck is still running sluggish at times. Half of the time it feels fine, acceleration is good from a stop and while driving. Seems as though RPMs are higher when accelerating before shifting. Also when driving it almost feels like the brakes are being applied and pulling the truck back but they are not. Any ideas, thanks in advance
Old 05-10-2008, 05:03 PM   #24
TallTexan
TallTexan's Avatar
I see you have a K&N filter. Some have oiled their filter too much and the oil gets on your MAF and causes problems.
Robert Louis Stevenson
Old 05-10-2008, 07:48 PM   #25
Guiseppe
Guiseppe's Avatar
no haven't done that yet, I haven't put oil on my filter could that cause it. I just pull it out and use air compressor to clean it.
Old 05-13-2008, 10:39 AM   #26
rgb133
this could be a problem with the trans module. did you lift it yourself?? if you did have a 4wd shop reprogram the shift points. the trans speed is what causes the trans to shift in relation to the engine speed. when you lift it the engine trans want to shift like stock. i dont know if titans ca be programmed for larger tires. its the whole thing about the speedo being 5 mph off. otherwise maybe an electrical issue. i may be wrong just a suggestion
rgb133 is offline   Reply With Quote
Old 05-14-2008, 03:49 PM   #27
Guiseppe
Guiseppe's Avatar
I have had my lift for 1 1/2 years and it just started acting up. Wouldn't that of happened when the shop did it?
Old 05-14-2008, 03:59 PM   #28
Carbeaux
Carbeaux's Avatar
You can't reflash your ECU to change the shift points by any means that I'm remotely aware of, so scratch that off.
Old 05-14-2008, 04:51 PM   #29
rgb133
on some vehicles the speedo does tell the transission the speed of the vehicle. but like isaid i was just throwing an idea out there
Old 05-14-2008, 05:33 PM   #30
skyhammer
You should never use compressed air on a K&N filter. If you read the instructions that came with the filter, it says not to do this as it will ruin you filter and either reduce the air flow or blow out the media so it does not filter properly, letting more dirt in.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
User Name
Password
Transmission cut out?? Transmission problem?? Titanman10 Titan Problems & Dealer Service 9 04-29-2008 08:58 PM
P1027 Service Engine Soon Check engine light Hendge Titan General Discussion 0 01-21-2008 01:28 PM
Engine hoist, engine stand & parts washer 4 sale!!!! Spectre Buy/Sell 2 01-05-2007 08:41 PM
Service engine soon and poor running engine CyBwRBill Titan General Discussion 16 09-08-2004 10:54 PM
Engine Light on & Transmission went Bad (HELP) Timan Titan Problems & Dealer Service 13 08-25-2004 08:40 PM
Search this Thread:
Advanced Search
vB code is On
