Old 05-06-2008, 08:01 PM   #1 (permalink)
A grave accident
Now, I bought my '05 titan, 47xxx miles, used, and decided to change the oil. While underneath, i went too the first thing that looked like an oil pan, unplugged it, got out from underneath, cleaned the plug, and went back underneath. by about this time, i noticed the fluid draining was red.
Anyways, i have some royal purple atf fluid laying around, and was wondering what the best, and cheapest way, to get the fluid level back up. is it alright to mix the fluids, or if its okay at all to use royal purple in the transmission at all, or if it would void the warranty.
Draco42 is offline   Reply With Quote
Old 05-06-2008, 08:59 PM   #2 (permalink)
HRTKD's Avatar
Re: A grave accident
Um, you don't have much of a choice if your Titan is your only means of transportation. There have been many discussions in this and other forums regarding the use of non-Nissan ATF. In most cases the conlusion is that you should stick with the Nissan Matic-J fluid.
I don't know anything about the RP ATF. If it was me and all I had available was the AMSoil ATF I probably wouldn't think twice about it.
Jim
Old 05-07-2008, 03:15 PM   #3 (permalink)
yamatitan's Avatar
Make sure you drained your tranny first. I bought a used titan and did the same thing. but turns out it was some kind of wierd sythetic oil the dealership used that was red in the engine. I filled it back up with Mobil 1 and have had no problems since. So check your dip stick and make sure you did not really drain engine oil.
Procomp 6" ($1300.00)
35x12.5x18 Toyo MT's $1100.00)
PRG Offroad Traction Bars ($489.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
SAW coilovers ($1000.00)
Bushwacker Pocket style flares ($600.00)
Rear Sway-away piggybacks ($399)
Money wasted so far=$9073.00
yamatitan is online now   Reply With Quote
Old 05-07-2008, 07:50 PM   #4 (permalink)
Shane06fl's Avatar
Trany pan is flat, oil pan is not. Trany pan is at the transmission and the oil pan is connected to the engine, pretty simple to tell the difference.
Until your warranty is done with stick with J matic. The RP or Amsoil will work fine to get you to the Nissan parts department but do another drain and fill with J Matic soon. Should take 4qts but buy 5 just in case.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC SE
Big Tow
4x4
Silver
Old 05-12-2008, 03:45 PM   #5 (permalink)
Thank you so much guys. Ill take your advice, and tell you how it goes later.
Up Skirt Look e Lou by accident.... Johnny08 Titan Interior Discussion 44 02-07-2008 09:15 AM
Bad Accident TriKKy Off-Topic Discussion 22 11-10-2007 01:48 PM
Accident Ditch64242 Titan General Discussion 15 01-03-2006 08:39 PM
Near accident Ditch64242 Titan General Discussion 2 01-02-2006 01:14 AM
Near Accident buzzkillwill Off-Topic Discussion 7 10-15-2005 08:17 PM
