Old 07-03-2008, 04:06 PM   #1 (permalink)
Diff. fluid change
I have a 05 B/T Titan 4x4 with 30,000 miles. I tow my TT and a utility trailer about 2-3 times a year. I ordered some Amsoil Diff. fluid (front and rear) to replace the stock fluid. Do I need to include any of the Amsoil Limited slip additive to the gear fluids when changed? How much fluid does the front and rear hold? Thanks for any imput.
TitanTodd is offline   Reply With Quote
Old 07-03-2008, 05:32 PM   #2 (permalink)
HRTKD's Avatar
Re: Diff. fluid change
According to the AMSoil web site:
Automatic Transmission, Total Fill
5 speed RE5R05A..........11.0 quarts
Differential, Rear..........4.4 pints
Differential, Front..........3.4 pints
Transfer Case,..........4.2 pints
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....26 ft-lbs
Drain Plug.....26 ft-lbs
You could measure out exactly what is called for above. But it's just easier to fill it until it just barely starts to leak out the fill plug.
I don't believe there is any need for additive in the read differential. My Ranger calls for additive but only because it has plates in the limited slip differential.
Jim
Old 07-03-2008, 07:41 PM   #3 (permalink)
TYTAIN's Avatar
No need for the limited slip additive, as the Titan does not offer a LSD diff.
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
12k Change Diff Fluid? Justintoxicated Titan Engine, Transmission & Drivetrain 6 03-30-2008 11:05 PM
Rear Diff Fluid Change @ 70K MongoDawg Titan Engine, Transmission & Drivetrain 3 02-11-2008 12:42 PM
Change your front diff fluid! Chris93Si Titan General Discussion 13 02-20-2007 06:10 PM
diff fluid change SHIPREC13 Titan General Discussion 8 09-04-2006 05:24 PM
When to change front diff. fluid? Colorado_Titan Titan Engine, Transmission & Drivetrain 7 03-25-2006 01:50 PM
