Old 10-12-2008, 10:03 AM   #1 (permalink)
SLOride's Avatar
Rear axle or trans problem?
yesterday i was driving home at around 50 55 mph when all of a sudden there was a hard CLUNK from the drivetrain, it felt as if the truck came out of gear or something, or like something was binding up. almost like i ran over a cinder block in the road or something, then the truck downshifted and the rpm's went up but no go, and just as fast it went back into gear. I tried the manual shift to see if i could get it to do it again but no luck because the manual shift would'nt work. after i came home and turned the truck off then drove it again later it was fine and the manual shift worked great. any ideas whats wrong?
SLOride is offline   Reply With Quote
Old 10-12-2008, 03:32 PM   #2 (permalink)
Learjet's Avatar
Re: Rear axle or trans problem?
to start, change your rear differential fluid and see if you have any gear pieces in the oil.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 10-12-2008, 03:43 PM   #3 (permalink)
titaninak's Avatar
this has tranny problems written all over it, i would change tranny fluid and then you should be able to tell,
1) are you driving your truck now? if so are you having the same problems?
2) is your tranny shifting harder than normal? if so your tranny is having issues
3) highly recommend this> take it into dealer and state your having shifting problems and let them diagnos this. Lastly, I hope your under warranty.
4) Good Luck with that.!!!!
2006 LE, CC, BT, 4x4-Blizzard White
JBA catback, K&N cai, poweraid TBS, grounding kit, 2 degree timing, UpRev tuned, TruTrac
Debadged,4 piece billet grille, 20"Akuza wheels, tech12's w/ Memphis PR1-1000 amp / M-10's, Kenwood 7019 DD,DVD HU, Line of Fire LED light bar, LED third brake light, smoked tails, EFX HID lows and fogs, painted to match MADA air dam / inchannel window visors, Stillen Billet aluminum cap covers, 15% front tint, Non BT mirror swap. Truxedo lo pro tonneau cover
titaninak is offline   Reply With Quote
Old 10-12-2008, 04:38 PM   #4 (permalink)
SLOride's Avatar
well, the truck is and has been doing fine until that moment yesterday with no out of the ordinary shifting patterns. i've broken a 5-speed trans by powershifting in my stang in the past, it came apart in third while spraying 125 shot on it and this felt alot like that, except it went back to driving and shifting normal. i just took the truck in 2 weeks ago for a blown axle seal, and since then my radiator is leaking (prob cracked) and now this. could the axle being fixed be linked to this? and could some of you that have had problems with broken diff's describe the sound it made when it went out.
thanks, DALE
Old 10-12-2008, 05:21 PM   #5 (permalink)
titaninak's Avatar
at a mininum take it to the dealer and state the problems your having so when it does take a _hit on ya you will have documentation that this was happening before it happens. JMO!
Old 10-12-2008, 05:45 PM   #6 (permalink)
SLOride's Avatar
oh i am gonna take it by there tomarrow but as far as documatation, it does'nt matter because i've got 80k on the clock. warrenty has left the building!
92 Lexus trans problem. abmobil Off-Topic Discussion 3 03-11-2008 10:10 PM
Rear axle Scott. Titan Engine, Transmission & Drivetrain 1 12-11-2007 08:14 PM
Rear axle seal and rear diff inspection Smoke05 Titan General Discussion 8 09-26-2007 02:21 PM
Confirmed vacuum in axle, is the vent the problem with leaks? Learjet Titan Engine, Transmission & Drivetrain 2 09-17-2007 01:04 PM
Axle Vent Mod Problem STRIPER1 Titan General Discussion 18 12-03-2006 11:50 PM
