Old 01-02-2009, 01:31 PM   #1 (permalink)
04 titan repetitive noise at low speed?
I have a 04 titan 4x4 with ~65k miles on it.
Stock.
Lately I have been having a repetitive noise at low speed. It reminds of gear whine, but only happens part of a tire or drive shaft revolution. It is completely dependent on speed, not RPM.
It sounds like a...
"whoo.... whoo....whoo...whoo....etc" The whoo's obviously get closer with the faster you go.
Any ideas on what this could be? Dreaded rear end about to blow?
What is the cost of a new rear for just parts since I do my own labor?
Thank you in adv!
JamesN1830 is offline   Reply With Quote
Old 01-02-2009, 01:45 PM   #2 (permalink)
Banned
bbomar's Avatar
Re: 04 titan repetitive noise at low speed?
Maybe a tire belt starting to slip.....
Old 01-02-2009, 01:57 PM   #3 (permalink)
Tires , breakpads or you picked up some trash.
I'll keep my freedom, my guns, and my money, you can keep THE CHANGE.
Bend is offline   Reply With Quote
Old 01-02-2009, 01:58 PM   #4 (permalink)
HRTKD's Avatar
Could be a wheel bearing, differential or transfer case also. If you put the entire Titan up on jacks and then put it in drive and keep the RPM's low you might be able to find the exact source.
Jim
Old 01-02-2009, 05:36 PM   #5 (permalink)
AF-Medic's Avatar
Mine does that too. I thought it was from the wheel spacers but isn't. Let me know what you find out. My bet is a wheel bearing.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's, Two 12 volt tech underseat subs with CDT 4100 and cdt replacment door speakers,MD DVD player with 8.5 screen Shift Pass You
AF-Medic is offline   Reply With Quote
Old 01-02-2009, 05:44 PM   #6 (permalink)
sudden urge's Avatar
I say tire or wheel bearing. As tires age and wear, they start making a whooing noise, but usually it's a fairly constant whooing and more noticeable at 30 MPH and under.
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 01-02-2009, 06:02 PM   #7 (permalink)
anmut's Avatar
Check for the easiest stuff first. Rock or nail in your tire.
Mods: Bully Dog Tuner · 2* Timing Advance · AEM Brute Force · Burn-out Mod @ ECU · 18" Magnaflow
Nissan OEM Brush Guard · Hellwig Traction Springs · 4 Hella 500FF OR Lights
Line-X Bed Liner · Jason Topper · Nasta Nerf Bars
Wish List: Nitto Mud Grapplers · Rims
Waiting For Support On: TruTrac / PowerTrax
SaveTheTitan Website IRC Chat: Server = Dalnet / Channel = nissan_titan
anmut is offline   Reply With Quote
Old 01-02-2009, 08:47 PM   #8 (permalink)
TallTexan's Avatar
It is a tire. Probable front end alignment prob. Mine has done this a couple of times. New tires and it all goes away. Also, rotate your tires will help.
Robert Louis Stevenson
General Question - low speed accident faith+1 Titan General Discussion 8 08-29-2008 03:52 PM
Low speed moan in front end! crash519 Titan Problems & Dealer Service 13 12-17-2007 10:14 AM
Low speed vibration solved. yagger Titan Performance Modifications 0 10-11-2007 12:23 AM
Strange Noise at Low Speed Convoy Titan Problems & Dealer Service 3 04-02-2007 10:34 PM
Strange sound at low speed when AC on mwheat Titan General Discussion 5 12-09-2004 05:27 AM
