Old 01-02-2009, 05:31 PM   #1 (permalink)
PRJ
Awesome
Axle shaft pulled out on passengers side up front today. 77,000+ so truck is out of warranty. Apparently there is no fix except a whole new front differential. Service guy said they used to just fix the axle shaft with a new c-clip but then Nissan redesigned the whole thing so now you have to buy the whole front diff etc. $1700 total to fix.
I had the service manager pull my records today. This was visit #23 since 2004.
Stupid Truck.
PRJ is offline   Reply With Quote
Old 01-02-2009, 06:19 PM   #2 (permalink)
Kronos1965's Avatar
Re: Awesome
Sorry to read about it but I'm glad it's fixed with a part that is better than the original.
HippieWhore™
Kronos1965 is offline   Reply With Quote
Old 01-02-2009, 06:40 PM   #3 (permalink)
daptech's Avatar
Re: Awesome
Originally Posted by PRJ View Post
.................... Apparently there is no fix except a whole new front differential. Service guy said they used to just fix the axle shaft with a new c-clip but then Nissan redesigned the whole thing so now you have to buy the whole front diff etc. $1700 total to fix.
I would investigate that situation some more before
I spent $1700. Sometime dealers make "mistakes"
2004 4x2 SE CC BT
daptech is offline   Reply With Quote
The Following User Says Thank You to daptech For This Useful Post:
konigfritz (01-24-2009)
Old 01-02-2009, 07:05 PM   #4 (permalink)
4mula1fan's Avatar
Re: Awesome
might be time to visit you local auto and truck recycler!
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up.
Grumpy Old Man Club
http://s3.bite-fight.us/c.php?uid=214743
4mula1fan is online now   Reply With Quote
Old 01-02-2009, 07:11 PM   #5 (permalink)
08TitanSE's Avatar
Re: Awesome
That sounds like the dealer is trying to pull a fast one on you. I would take it to a local "trustworthy" mechanic since you are out of warranty for a second opinion
08TitanSE is offline   Reply With Quote
Old 01-02-2009, 08:22 PM   #6 (permalink)
Re: Awesome
^^^^ditto.
2008.5 KC Pro4x
current mods: S&B cai, magnaflow muffler swap, OEM bugshield
mod's wanted: lots.
asher is offline   Reply With Quote
Old 01-02-2009, 08:39 PM   #7 (permalink)
Smoke05's Avatar
Re: Awesome
Funny, mine said the same thing, yet Courtesy Nissan shows a parts breakdown of the front final drive with what appears to be full availability. I called mine on it and now they are looking for a new carrier instead of the entire final drive assembly. If they don't play it will be off to the State Attorney General and a then a part recycler and a independant shop or I will shed some sweat and do it myself. I know sales aren't good but raping us in the service department is not making me want to head out to Nissan and buy another one of their products and certainly not from my once reputable dealership.
Smoke05 is offline   Reply With Quote
Old 01-02-2009, 08:59 PM   #8 (permalink)
PRJ
Re: Awesome
Like I said, the dealer allegedly stated he used to just replace a few parts for this problem up until recently when Nissan re-designed something or other forcing you to replace the whole works. In the past 23 visits this dealer has been fair to me, although I am a little skeptical like some of you also.
Old 01-04-2009, 07:49 AM   #9 (permalink)
PRJ
Re: Awesome
I called a second Nissan dealer in the area yesterday and got another opinion. He told me the same thing as the other dealer. Apparently they used to just change the shaft and put in new c-clip, but that didn't work and the customers kept coming back to have it repaired. He told me the same thing as the first dealer--Nissan redesigned the whole front differential and now recommends replacing the whole thing.
Something tells me Nissan never put this truck through R & D testing very well. The rear end, front end and brakes and numerous other issues would have showed up well before the product was released to market.
Old 01-04-2009, 08:28 AM   #10 (permalink)
daptech's Avatar
Re: Awesome
.................... --Nissan redesigned the whole front differential and now recommends replacing the whole thing.
That's fine if it is covered by warranty, but Nissan should have
repair parts available for those out of warranty & the owner
would rather try to repair than replace.........sounds like
more Nissan BS............but may not be too surprising with
the Nissan Titan near end of production.........repair parts
may become more of an issue no matter what regulations say.
2004 4x2 SE CC BT
Old 01-04-2009, 10:55 AM   #11 (permalink)
Re: Awesome
same issue here. I have 99K miles. My turn. Quoted $1500 for the fix by the dealer. I've tried the Nissan experiment and I can say this is my last Nissan. Back to GM I go.
tmoran is offline   Reply With Quote
Old 01-04-2009, 11:00 AM   #12 (permalink)
4mula1fan's Avatar
Re: Awesome
Originally Posted by tmoran View Post
Back to GM I go.
And buy a new one every 5 years......
Grumpy Old Man Club
Old 01-04-2009, 03:15 PM   #13 (permalink)
gabriel c.'s Avatar
Re: Awesome
warranty is longer than the titan. in my case i rack about 5k to 6k miles a year, i will be way out of warranty when all these problems start appearing.
third coast titans
gabriel c. is offline   Reply With Quote
Old 01-04-2009, 05:33 PM   #14 (permalink)
PRJ
Re: Awesome
I don't know if I would go to GM, but this may be my last Nissan also. At least in a truck.
Old 01-04-2009, 07:03 PM   #15 (permalink)
Re: Awesome
I truly believe there is a difference in engineering though. First the brake issue, then the wet passenger side floor boards, the axle seals, rear tail shaft seal, front drive shaft/diff seal. Where did they test this thing during development the mall? Nissan probably has this stuff worked out by now but wow, to the market to early. A buddy of mine worked in the R&D facility and claims Nissan has "counter measures" (or engineering fixes to known issues) in a lot of the 06 and 08 driveline.
awesome forum & awesome truck!!!! vulcanrob Titan General Discussion 14 05-08-2007 08:46 PM
This is awesome!! baggettp Off-Topic Discussion 4 01-12-2007 05:35 AM
VDC is awesome Mike Up Titan General Discussion 38 12-12-2005 01:23 PM
Awesome Grill pi3yeargrad Titan Parts & Accessories 1 11-05-2005 12:52 AM
This is Awesome... joekrz Titan Problems & Dealer Service 9 02-17-2005 11:40 PM
