Diesel Titan - Nissan Titan Forum
post #1 of 15 (permalink) Old 05-15-2009, 01:51 AM Thread Starter
06_SMOKE_SE_CC's Avatar
iTrader Score: 1 reviews
Diesel Titan
alright, this is kinda a 'what-if' thread just to see what could be done
so i've heard alot of people saying they want the diesel in the titan, i agree with them, that'd be sweet...but seeing as there isn't one right now, what if you could put one in?
if money was no object, because i think if it was, this would probably never get done....is there a diesel engine/tranny combo that could be stuffed in the titan engine bay/drivetrain?
i know pretty much zero about diesels, so i'd be interested to see if there is anything out there that could make this project a possibility....not that i'm planning on doing it, cause i don't have thousands of dollars to spend on it....and it'd probably be cheaper/smarter to just buy a diesel, but let's just say for keeping-the-titan-sake, could it be done?
i'm a one man wolf pack....
MODS DONE:
cst 4" spindles, radflo 2.0 coilovers w/3" preload, deaver c-30 spring pack, sway-a-way piggybacks, aem bruteforce w/dryflow, cherry bomb extreme muffler, t-rex billet upper grille, 35" kumho mt's, pioneer avic-n2 nav unit with ipod integration, pacific audio steering wheel control adaptor, smittybilt sure step black side steps, DDM Tuning 55w 6000k HID lows, black xe steelies
06_SMOKE_SE_CC is offline
Advertisement
post #2 of 15 (permalink) Old 05-15-2009, 05:48 AM
NBhunter80's Avatar
iTrader Score: 0 reviews
Re: Diesel Titan
Anything can be done if you have enough money. You would definitely have to swap both axles, and get some HD suspension to handle the extra weight. Then throw in a 12-valve cummins with built tranny!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #3 of 15 (permalink) Old 05-15-2009, 06:48 AM
Shane06fl's Avatar
Re: Diesel Titan
I think the Cummins would be too long to fit. A V8 D would be the best fit I would think. Now is there enough room for the Turbo?
If I could do it I would probably go with a D-max and Allison trany.
And yeah the rest of the driveline and suspension would need a upgrade too.
2005 Titan KC SE ***Sold 9/6/14***
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
2013 Chevy Silverado LT Z71 CC short bed
5.3L LC9 engine
Heavy duty tow package/cooling
4wd
loaded to the gills
mirrors sucks (for now)
2004 Keystone 24RS
Shane06fl is offline
post #4 of 15 (permalink) Old 05-15-2009, 09:19 AM
Steelyeyedone's Avatar
iTrader Score: 10 reviews
Re: Diesel Titan
Yup. Duramax and Allison. Get a programmer. And beef up all the under pinnings.
2008 Nissan Titan LE CC 4x4 LWB
Mods
Steelyeyedone is offline
post #5 of 15 (permalink) Old 05-15-2009, 09:23 AM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
Re: Diesel Titan
About 12 years ago one of my father's truck drivers has his chevy 350 converted into a diesel motor. I know they swapped out the spark plugs for glow plugs, and did some other things but the shelf life on the details has expired.
Is that what you were thinking or were you leaning towards what's been posted above? complete new motor, trans, axles, and probably engine management system?
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #6 of 15 (permalink) Old 05-15-2009, 09:28 AM
nnak58's Avatar
Re: Diesel Titan
??? It would have been easier and cheaper to just do an engine swap.
2007 Titan XE KC Galaxy Black
Line-X bedliner
Flood lights installed in bed walls
Airraid Intake
Power tailgate lock
6 Head strobe light system
Strobes in headlights, cargo lights, and taillights
Federal Signal headlight flasher
100 Watt Federal Signal SmartSiren
LED bumper warning lights
AVS bugshield
LED grille marker lights
Other rides:
2007 Altima 2.5S 1998 Ford Windstar
1987 Ford Bronco "Big Fugly" 1999 Dutchmen 30FK TT
nnak58 is offline
post #7 of 15 (permalink) Old 05-15-2009, 09:58 AM
DeadRiver's Avatar
Re: Diesel Titan
Alright, I had to call my dad to confirm what happened.
The driver had a 350 V8 diesel motor in his chevy car.
He pulled that motor out and put a 350 gas motor in.
My memory is far worse than I thought
For some reason I remember a dialog about converting gas motors to diesel.. ah well
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
PA Chapter Director
The Urinator™
post #8 of 15 (permalink) Old 05-15-2009, 10:55 AM
NBhunter80's Avatar
Re: Diesel Titan
Yeah, I don't know if a traditional block and stuff could handle the pressure of compression ignition.
post #9 of 15 (permalink) Old 05-15-2009, 01:13 PM
Shane06fl's Avatar
Re: Diesel Titan
a gas engine doesn't produce enough compression to ignite D-fuel. The only thing the glow plugs do is aid in a cold start by heating the fuel so it will pop easier.
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
post #10 of 15 (permalink) Old 05-16-2009, 07:25 AM
Re: Diesel Titan
Cummins makes a 4 cyl 4tb the same design as the 6 cyl. You can use the same parts to incease horsepower, A guy put one in a early bronco pushing 350 hp, it's a monster. The engine and trans comes from box trucks, cummins with a turbo 400 gm trans, but all gm trans mounts the same so an overdrive trans could be swapped. The weight would not be as big of an issue, you would have an unlimited options for transfer cases but would the famous titan axles hold up to 450 - 500 ftlbs of troque?
titanmadman is offline
post #11 of 15 (permalink) Old 05-16-2009, 08:07 AM
mjw357's Avatar
Re: Diesel Titan
I think you can do it by swapping out the heads, intake etc. One of my childhood friends uncles did this to a '70s chevy pickup. I don't think it would run worth a sh*t with just glow plugs, like you said very low compression (8:1 maybe?) versus typical 50:1 for a diesel.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
mjw357 is offline
post #12 of 15 (permalink) Old 05-16-2009, 10:56 AM Thread Starter
Re: Diesel Titan
lol, i knew there would be the response, 'anything can be done with enough money'.....that's why i said, 'if money was no object'.....just curious what could be done.....
it would be interesting to see it done...that 4 cyl option sounds like it could be kinda cool....would seem weird to have a 4 cyl titan though.........
MODS DONE:
post #13 of 15 (permalink) Old 05-16-2009, 11:41 AM
Shane06fl's Avatar
Re: Diesel Titan
Thats right they run like sh$t and have no power. Remember for many years GM tried to make a diesel out of the 454 block. It was used in the Olds Delta 88 and 1 ton's. I even seen one in a Cadilac. It was weak and not very reliable. They did just what yu said, they swapped heads and put higher compression pistons in it. But a stock gasser will never ignite diesel.
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
post #14 of 15 (permalink) Old 05-16-2009, 01:19 PM
Re: Diesel Titan
The shop that I use to work at, could do it. Just type in smokindiesel.com. It would take alot of money. But this guy is good at it. He sell titan stuff also.
wvtitan08 is offline
post #15 of 15 (permalink) Old 05-16-2009, 04:23 PM
desertruner09's Avatar
Re: Diesel Titan
I vote this! Not only would weight be a smaller issue, but I think it would be a manageable size for the somewhat small Titan engine bay, better suit to half ton needs, and very little modification of the frame and suspension. I don't think I'd use the Titan's rear axle for it though, I'd look to something a bit stouter.
If you try to stuff one of the larger engines in you would have to upgrade the frame, suspension, and axles just to hold the engine up, which means payload would take a huge hit if it isn't completely gone. If you wanted to add that loss payload back, then that means even more frame, suspension, axle mods. So in the end, it would probably be better to just buy a rolling chassis from Dodge/GMC/Ford and put a Titan body on it or design from the ground up.
2006 Titan 2wd CC SE Granite w/Big Tow with 150K miles
2006 BMW 330i w/Sport Package as my DD
desertruner09 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Titan Diesel TitanTech659 Future Titan Discussion 55 05-26-2008 03:18 PM
Titan to get Diesel and a V6 Pokoki Titan General Discussion 74 10-20-2007 09:55 AM
09 Titan Diesel? dmc601 Titan General Discussion 11 09-01-2007 08:28 AM
Here's the Diesel for the Titan..... TitanFan59 Off-Topic Discussion 10 01-26-2006 05:32 PM
Diesel TITAN!!!!!!!!! dcrobt Titan General Discussion 4 08-14-2004 11:12 AM
You may post new threads
You may post replies
