Old 06-29-2009, 12:20 PM   #1 (permalink)
OEM E-Locker on 4x2 Titan
Could i put a oem e locker on a 4x2 titan and rewire it to make it lock? Or should i just buy a tru trac?
2004 Titan 4x2
MODS:
Flowmaster 40's
Bilstein 5100's
To-Do List:
Interco Vortrac
(35-12.5R18)
PRG Shackles
RC 3" Level w/UCA's
RC 1.5 R block
TruTrac? (alot of $$)
Mx851 is offline   Reply With Quote
Old 06-29-2009, 10:44 PM   #2 (permalink)
loufish's Avatar
Re: OEM E-Locker on 4x2 Titan
Yes you could, just make sure you get the right E-loc for the right year...04-07 are all the same...08+ are the same.
You can get a TruTrac for 04'-07' Titans, the big advantage of a TT over the factory E-loc is that the TT replaces all the spyder gears....which is the part most likely to fail....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 06-30-2009, 02:06 AM   #3 (permalink)
vilim12's Avatar
What he said, but if your 04-07 id go with the truetrac instead of a diff swap. Those year e-locker diffs werent very strong at all. 08+id go for an e locker, but if truetrac was available id go for the truetrac. Lots of guys with the 04-07 have ditched the e-locker for the truetrac
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 06-30-2009, 03:10 AM   #4 (permalink)
loufish's Avatar
I've had the TT for several months now, I'm VERY happy with it...
Was it worth the price?.....YES!
Born 9/2004
2002 Honda XR650R
Old 06-30-2009, 09:45 AM   #5 (permalink)
Well thats good to know, i was wondering if the TT would be worth it because 1 wheel drive is getting annoying. I dont do alot of hardcore off roading but even playing in gravel pits and light mud is tough in stock condition
2004 Titan 4x2
MODS:
Flowmaster 40's
Bilstein 5100's
To-Do List:
Interco Vortrac
(35-12.5R18)
PRG Shackles
RC 3" Level w/UCA's
RC 1.5 R block
Old 06-30-2009, 09:47 AM   #6 (permalink)
Juday's Avatar
If you're looking to get a full locking unit, ARB makes one for the Titan.
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
Old 06-30-2009, 12:26 PM   #7 (permalink)
Ya a full locking unit would be nice but it is also $900+ and only works on certian Titan rear ends and i do not believe a 4x2 is one of them.
2004 Titan 4x2
MODS:
Flowmaster 40's
Bilstein 5100's
To-Do List:
Interco Vortrac
(35-12.5R18)
PRG Shackles
RC 3" Level w/UCA's
RC 1.5 R block
Old 06-30-2009, 06:04 PM   #8 (permalink)
TitanBlue's Avatar
I'll have to learn more about that ARB. My 06 rear just got replaced with an 08 today. I can't imagine a 4x2 having a different rear than a 4x4. but, you never know.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 06-30-2009, 07:36 PM   #9 (permalink)
Juday's Avatar
Every Titan comes with the M226 rear...
Edit: Looking at the ARB website, it seems as though the locker is designed for the 2005+ models.
http://www.arbusa.com/uploads/PDF/ne...149_pr_web.pdf
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 06-30-2009, 08:06 PM   #10 (permalink)
twistedfreedom's Avatar
Send a message via AIM to twistedfreedom
Titan blue did you get your tru Track when they replaced the rear end?
overview
08 KC XE Galaxy Black, Color matched front and rear bumpers, De-Badged, Charcoal interior, "Carbon fiber" inserts
Sound
4 Infinity 6x9's, pioneer head unit, Kenwood 900w amp, Kicker L7 10" sub
Performance
K&N w/ airbox mod, Bully Dog GT tuner, flowmaster 50 series Dual 2.25" in single 3" out,2*, PRG 2" leveling kit.
Coming soon
UpRev, Nismo headers, JWT cams, IPT trans, Nismo cat back and My tail lights in your face
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
twistedfreedom is online now   Reply With Quote
Old 06-30-2009, 08:46 PM   #11 (permalink)
TitanBlue's Avatar
No, it doesn't fit 08, and I know what you are really thinking. I couldn't get hold of the axle to take home and recover the TT. I have little doubt it was fine. I'll be saving pennies a long time to get me an ARB.
Old 06-30-2009, 08:55 PM   #12 (permalink)
I'm pretty sure the ARB doesnt work on the 08 axle. I'm going the E locker route
overview
Sound
Performance
Coming soon
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
Old 06-30-2009, 08:59 PM   #13 (permalink)
vilim12's Avatar
Isnt the E locker swap kinda difficult?
Crew Cab Long Bed
Old 06-30-2009, 09:02 PM   #14 (permalink)
I doubt honestly it should be a pretty simple swap spline count is the same. Just bolt on the rind gear set the back lash, run some wires and be done with it
overview
Sound
Performance
Coming soon
15.032 @ 92.48MPH
hp295.64 tq330.33
MD Rep
PINKBARBIEWHORE™
Old 06-30-2009, 09:02 PM   #15 (permalink)
TitanBlue's Avatar
Just buy the whole axle at a Junkyard. After that, (I may be wrong) I think it is just a 2 wire hookup with a manual switch in the cab. It all bypasses the ECU.
wtb: front oem 4x2 low mileage shocks Titantexan Buy/Sell 8 02-18-2007 11:39 AM
TruTrac locker for the Titan? Hawaiianbasshead Titan Performance Modifications 476 06-22-2006 11:42 PM
Do I have the locker in my Titan? ucf_motorcycle Titan General Discussion 7 05-30-2006 03:10 AM
OEM Skid Plate on KC SE?? 4x2 soanso Titan Parts & Accessories 3 03-01-2005 11:52 AM
Detroit Locker, ARB air locker, Easton e-locker pluckyew Titan General Discussion 43 11-29-2004 05:53 PM
