Old 08-26-2009, 03:26 PM   #31 (permalink)
blk04titan's Avatar
Re: Gears are out!!!
So which ones should we buy???????
....A bunch of stuff..... And lots more to come
blk04titan is offline   Reply With Quote
Old 08-26-2009, 03:43 PM   #32 (permalink)
blk04titan's Avatar
K well now the question is also where is the cheapest trutrac??????
Old 08-26-2009, 03:57 PM   #33 (permalink)
undy's Avatar
wow.. 2 shops to order gears from, its like christmas 5 years late. time to start collecting my pennies.
2005 CC SE 6 Seat Pop. Package
Exterior: 6" Pro Comp Suspension Lift * 3" Body Lift * 37x13.50x20 Toyo O/C Tires * 20x9 Ballistic Offroad Hostel Black Wheels * Bushwacker Pocket Fender Flares * T-Rex 1 pc. Upper and Lower Grille (black)
Interior: Panasonic CQ-VD6503U DVD/NAV Head Unit * Kicker ZX1500.1 Amp * Kicker ZX350.4 Amp * (2) RE SE 10" Subs * Tech12 Foward Firing Ported Enclosure * Infinity Reference CS6020 6.5" Speaker Set w/ (6) Silk Dome Tweeters All Around * Custom Stainless Nismo Gauges
Performance: Superchips Cortex 87 Tune * AEM Brute Force Intake * Flowmaster Super 40 Series Dumped
Next to come: A lot on my mind
undy is offline   Reply With Quote
Old 08-26-2009, 04:02 PM   #34 (permalink)
blk04titan's Avatar
and whats the best diff cover for us too??? lol the pml or the magtec or stillen?????
Old 08-26-2009, 07:52 PM   #35 (permalink)
welder530's Avatar
ok so i feel retarded for asking but.. what gears does my stock 07 4x4 have? whats the difference between all the gears that are now out and what would the benefits be? im new to the modding scene and would like to know everything i can.
welder530 is offline   Reply With Quote
Old 08-26-2009, 08:02 PM   #36 (permalink)
blk04titan's Avatar
do you have the bt????? and if you are lifted or have bigger than stock tires it would help a lot, no lag in power and will help for towing as well.....
Old 08-26-2009, 08:20 PM   #37 (permalink)
welder530's Avatar
um? whats bt? yeah i have 6" suspension lift and 33" tires. soon going to install n20 and tru-trac. any suggestions on what gears would work best for my situation?
Old 08-26-2009, 08:48 PM   #38 (permalink)
rynomx785's Avatar
BT is Big Tow Package. It comes with the 3.36 gears as opposed to the 2.94 gears that all other Titans have in them. 3.73's would work with your set up it sounds like. It will just give back some of the power that you lost with the bigger tires.
Old 08-26-2009, 08:52 PM   #39 (permalink)
vilim12's Avatar
If you plan on moving up to 35s then I would get 4.11s, but if your planning on staying at 33s then I agree with rynomx about the 3.73s
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is online now   Reply With Quote
The Following User Says Thank You to vilim12 For This Useful Post:
CL 8 2WD (08-26-2009)
Old 08-26-2009, 08:59 PM   #40 (permalink)
welder530's Avatar
so if i switch out my rear gears with the 3.73's will i still be able to put it in 4wd without breaking anything or will i have to stay just 2wd till fronts come out?
Old 08-26-2009, 09:01 PM   #41 (permalink)
vilim12's Avatar
Id stay in 2wd, but the problem with that is who knows if front gears are ever even gonna come out?
Crew Cab Long Bed
Old 08-26-2009, 09:03 PM   #42 (permalink)
Do you need a new diff cover to install the new gears?
rsh46 is offline   Reply With Quote
Old 08-26-2009, 09:07 PM   #43 (permalink)
rynomx785's Avatar
I wont run 2 different ratios in my truck. Thats why I'm waiting until they come out with front gears. If they dont I guess that I'll never get to run 37's.
Old 08-26-2009, 09:08 PM   #44 (permalink)
rynomx785's Avatar
No you do not.
The Following User Says Thank You to rynomx785 For This Useful Post:
rsh46 (08-26-2009)
Old 08-26-2009, 09:30 PM   #45 (permalink)
CL 8 2WD's Avatar
Originally Posted by rynomx785 View Post
No you do not.
But they do hold more gear oil , and the mag hytech looks so nice
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
what gears 2wd06titan Titan Engine, Transmission & Drivetrain 7 01-02-2009 11:09 PM
The Gears onelowmini Titan Engine, Transmission & Drivetrain 19 05-22-2007 12:36 AM
Gears? Warp09 Prerunners.com - Titan Leveling Kits 2 04-29-2007 02:13 PM
gears please!! audiocar Titan Performance Modifications 7 03-21-2006 07:47 PM
gears mudfinder Titan Engine, Transmission & Drivetrain 5 10-03-2005 06:03 PM
