Well that settles it no gears for me i use cruise control everyday
2008 SE 2WD:
PRO COMP Kit, PRG UCA, with Radflows 2.5 Externals sitting upfront at 9.5" and rear 3' with MX6 Rear shocks. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. Injen CAI,
hey guys but their still aint no tru trac fot the 2008+?
2008 SE 2WD:
i hope they really do have gears that work for the 2009s but i wonder why there was no mention on the website just 2004 to 2007??? Does any company have plans to make Trutrac for the 2008+?
what modification did hoopers do in order to fit a 35spline axle shaft into a 32 spline designed TRUTRAC?
do you machine off 3 of the 35 splines on the axles and fit it into the tru trac with machining work? Do you machine the tru trac components as well?
someone has to know...
Correct me if i am wrong. I believe the trutrac is made for the titan. The gears they install are not.
__________________ 04 Black Crew LE
4" CST Lift With 3" Stacked On Top
325/65/18 Toyo A/T's On Stock LE Wheels
Custom Flowmaster Exhaust
K&N Drop In W/ Air Box Mod
Billet Front
Belltech Struts Set At +1"
JBA Headers
Magnaflow Cats
More to come!
80 Chevy RCSB, Step Side- The old High School Ride,
04 Saturn Ion 4 door- The Wifey's Daily Driver
65 Mustang- Coupe 289 Needs Restoration
04 Buell XB12R- My Fun/Summer Commuter
69 Honda Ct 90- Great for Hitting the Trails
125cc Pit Bike- Great for Chasin around The "90"
is its made for the titan years 04-07 but not for the 2008 due to the change of axle shaft spline count of 32 splines (04-07) to 35splines (2008+)...
There are some members on here and other sites that have 2008 models with a modification done by Hoopers in order for the trutrac to fit.
The modification can't be that major if it only takes about a day for the install and mod to make it all work.
If the modification was released then Eaton wouldn't have to make a new TT for the 08+ models, we could just buy the original trutrac, have the modification done at a local rear end shop, and be on our way... its not like hoopers would lose business from anyone on the east coast or in california.
someone with rear end knowledge could have some ideas or suggestions on how to make it work....
Cory J.
2008.5 Titan FFV SE crew cab
'Smoke'
MODS:
Doug Thorley (longtube) Headers
Superchips Cortex (93 performance tune w/3* adv)
Magnaflow dual in/dual out muffler (2.25in)
Magnaflow TRU-X crossover and rear dual exit
S&B cai w/ Ram Air mod
Reason: plus
I stand corrected. I to would be interested to know. Think that the female splines are somehow swapped from the stock dif to the trutrac? Basically where the axle shafts insert the trutrac, is that piece removable and possibly swapable (not a real word) ??
Billet Front
JBA Headers
Magnaflow Cats
More to come!
First I've heard of this...Are you sure?
The only way to get 35 spline axles into a 32 spline TT would be to replace the TT's side gears with units from another TT application that runs the same size 35 splines AND fits into the Titans TT case...If that was the case, wouldn't Eaton simply do the same them selves...
PRG Performance Kit w/SAW's
Born 9/2004
See i'm so glad you brought that up. We would think so that dana would do that right..lol? Maybe their focus is elsewhere.
Hoopers is in my back yard, I'll contact them and get the full story....
Born 9/2004
They are in your back yard??? What the hell are they doing back there, you must own alot of property. Sorry, couldnt help myself.
Billet Front
JBA Headers
Magnaflow Cats
More to come!
....I just might have had that one coming....
thanks for the laugh!
Born 9/2004
if all you guys want detroit tru trac for your 08+ i say bombard thier site with emails asking why they havent made one yet, also state that hundreds if not thousands of the 04-07 have sold so why not take a chancew on the newer titans?
05' Blizzard White 4X2 KC SE
Wheels: Foose Speedster 6 22's /w Nitto 420-S 305-40R-22
Upcoming Turbo Install coming this July!!
Will consist of a
Garrett GT4094R Ball bearing turbo, Tial 60mm Wastegate, Tial 50mm "Q" Blow off valve, Spearco Intercooler, etc...
