Old 09-09-2009, 05:53 PM   #76 (permalink)
undy's Avatar
Re: Gears are out!!!
Originally Posted by themaildude View Post
Titan007, have you had the gears installed yet? I am anxiously waiting for your report.
x2...
2005 CC SE 6 Seat Pop. Package
Exterior: 6" Pro Comp Suspension Lift * 3" Body Lift * 37x13.50x20 Toyo O/C Tires * 20x9 Ballistic Offroad Hostel Black Wheels * Bushwacker Pocket Fender Flares * T-Rex 1 pc. Upper and Lower Grille (black)
Interior: Panasonic CQ-VD6503U DVD/NAV Head Unit * Kicker ZX1500.1 Amp * Kicker ZX350.4 Amp * (2) RE SE 10" Subs * Tech12 Foward Firing Ported Enclosure * Infinity Reference CS6020 6.5" Speaker Set w/ (6) Silk Dome Tweeters All Around * Custom Stainless Nismo Gauges
Performance: Superchips Cortex 87 Tune * AEM Brute Force Intake * Flowmaster Super 40 Series Dumped
Next to come: A lot on my mind
undy is offline   Reply With Quote
Old 09-09-2009, 05:57 PM   #77 (permalink)
blk04titan's Avatar
I got it too!!!!! I cant wait for the front gears!!!!!!!
slowly paying for new front end!!
j-arm baby!
blk04titan is online now   Reply With Quote
Old 09-24-2009, 06:20 PM   #78 (permalink)
I recieved my 4:56 gears yesterday. They should be installed by tomorrow. I can't wait to see how the truck performs.
By the way, Chad at Superior Axle & Gear has done a great job working with me. I'm extremely impressed by their customer service.
PERFORMANCE: Stillen Supercharger, IPT Tranny rebuild, Stillen Longtube headers, JBA Exhaust, Injen Powerflow CAI, Osiris & Cypher, 4:56 rear diff gears
SUSPENSION: 9" Fabtech/PRG lift, 3" PA Body Lift, Bushwacker GM Cutouts, Extreme Pinch Weld Mod, Cepek Mud Country 40's, Sway bar removed, Air Lift Air Bags, Roadmaster Active Suspension
EXTRAS: AP Racing 6-Piston Big Brake Kit, Viair Air Compressor, Dunder Grill, Custom reciever lowered to pull a 31 foot travel trailer
WANTED: Front diff 4:56 Gears
Dads_taxi is offline   Reply With Quote
Old 09-24-2009, 08:00 PM   #79 (permalink)
TorkMaster's Avatar
Thats awesome man.
I have a question for you guys, I have 35inch tires and I cant decide between the 4.10 and 4.56 gears. Would 4.56 be to much for 35s? What is the differents on the freeways and around the city?
2004 King Cab Titan Deep Water
Performance Mods: Cortex SuperChip | 2* Timing | K&N FIPK CAI | Spintech Pro Street Custom Exhaust
Exterior Mods: CST Spindles w/ ICON Coilovers | Bilstein for the rear | PRG UCA's | rear add a leaf | 35x12.50x17 Pro Comp Xtreme A/T on Pro Comp 6089 Rims | DdM HID 5000k | Big tow Mirrors | tow hooks | Aftermarket Hitch | 20% Tint | WeatherTech Dark Smoke Side Window Deflector| Lund Genesis Tri-Fold Tonneau Cover | Back up Camera | OEM Running Boards
Toys: 2007 Honda TRX450
TorkMaster is offline   Reply With Quote
Old 09-24-2009, 08:53 PM   #80 (permalink)
rynomx785's Avatar
Originally Posted by TorkMaster View Post
Thats awesome man.
Go with the 4.10's. 4.56's are pretty low for 35's.
Old 09-24-2009, 09:06 PM   #81 (permalink)
loufish's Avatar
I have a set of 3.73 gears with 35" tires and these gears give me a stock tow package ratio, so running 4.10 gears would be lower then stock even with 35" tires...
i'll be going with 4.10 sometime in the future...
P.S Don't forget the TruTrac.....
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
Old 09-25-2009, 02:43 PM   #82 (permalink)
ok, so here's an update. Shop still working on minor issues. Ring and pinion was designed to be used with original Carrier so there is a design fit issues with using with tru trac install. Superior has a fix it's a ring spacer that's designed to make up the difference so that the ring and pinion don't have any play. They claim that the bolts still should be fine with the added spacer. Last week ran into a problem didn't have a crush sleeve or bolts for the new ring and pinion so had to buy a install kit from Superior designed for new gears. For those wanting to know about cruise control. I'm pretty sure you won't have it since the original locker(carrier) is electronic and tru trac is not therefore not plugged into wiring which sends signals to computer about rate of speed in which the gears turn. Should know next tues if all works.
titan007 is offline   Reply With Quote
The Following User Says Thank You to titan007 For This Useful Post:
themaildude (09-25-2009)
Old 09-25-2009, 03:32 PM   #83 (permalink)
themaildude's Avatar
Thank you for the update. Staying tuned for final results.
IRC CREW MEMBER
Click Here For My Mods
themaildude is offline   Reply With Quote
Old 09-25-2009, 04:12 PM   #84 (permalink)
Doc P's Avatar
Subscribed. wanna see how they turn out!!!
Mods: 8" CST lift w/ shocks, 3" BL, Gibson Dual Extreme, 20x10 XD Rockstars, Toyo MTs 37s, K&N CAI.
Superchips programmer and No Fear grille in a couple days....
Shes not the prettiest horse in the barn, but I wouldnt kick er outta bed for eatin oats
Doc P is offline   Reply With Quote
Old 09-25-2009, 04:44 PM   #85 (permalink)
blk04titan's Avatar
who uses cruz anyway???
j-arm baby!
Old 09-25-2009, 04:53 PM   #86 (permalink)
undy's Avatar
What is the word, I am very interested because I will be running 4.56's as well.
It's hard to use it in so cal with all the traffic, I use cruise daily.
Old 09-25-2009, 07:30 PM   #87 (permalink)
Ya but your gonna wish you had done the tru trac exchange when you rearend fails at the most in opportune time. The original spider gears(carrier) are crap the teeth break off.
Old 09-25-2009, 07:41 PM   #88 (permalink)
undy's Avatar
hmmm? you lost me there.. I plan on running tt and 4.56's, cruise or not, but I definitely will miss it.
Old 09-25-2009, 07:48 PM   #89 (permalink)
loufish's Avatar
I know it's not you, but that isn't making sense...
The TT is made to the exact same spec's as the factory carrier, that's why it's a straight bolt in, no spacers, no machining....so why would gears that are supposed to bolt right in not fit?....It's NOT the TruTrac...
And the C/Control not working although is true, but isn't because the factory locker is now missing...Think about it, most people DON'T have that locker yet they have C/Control.... The C/C get's it's speed signal from the rear wheel ABS rings...
I hope they get things straightened out...
Born 9/2004
2002 Honda XR650R
The Following 2 Users Say Thank You to loufish For This Useful Post:
CL 8 2WD (09-27-2009), rynomx785 (09-26-2009)
Old 09-25-2009, 08:07 PM   #90 (permalink)
blk04titan's Avatar
Im getting 4.56 too... and tt.. but im stuck between doing a new rear setup with the tt gears and cover/ diff cover and running gauges
and
being the trial titan at Giant motor sports... Greg is the only one to have their setup put in, but because he had a 9" and sh!t already done back there, they dont have it completely setup, I called and talked to em today and thats when they told me that, and that if I get my stuff done they would take off like 300 bucks if I do it!!! so idk.....( and im talking about a spring under kit)link below
Giant Motorsports - Offroad Race Truck Suspension Specialists | Nissan Titan 64" Long Travel Kit | giantmotorsports.com | Travel, Kit, Long, Giant
I need some help deciding.... I was gonna wait on everything due to financial props. but I figured it all out and The honda corp. just f'ed up!! I hate honda!!
j-arm baby!
what gears 2wd06titan Titan Engine, Transmission & Drivetrain 7 01-02-2009 10:09 PM
The Gears onelowmini Titan Engine, Transmission & Drivetrain 19 05-21-2007 11:36 PM
Gears? Warp09 Prerunners.com - Titan Leveling Kits 2 04-29-2007 01:13 PM
gears please!! audiocar Titan Performance Modifications 7 03-21-2006 06:47 PM
gears mudfinder Titan Engine, Transmission & Drivetrain 5 10-03-2005 05:03 PM
