Old 10-26-2009, 10:31 PM   #121 (permalink)
Re: Gears are out!!!
Originally Posted by titanridinghigh View Post
Lets just say 08 and 09 gears were released...
My delema would be that I'd want the 3.73's back, however I have since then fallen in love with my cruise control....
Is there any way i could have the best of worlds??
Are you sure about the cruise?
I had my 4:56's installed about a month ago and my cruise control still works!
PERFORMANCE: Stillen Supercharger, IPT Tranny rebuild, Stillen Longtube headers, JBA Exhaust, Injen Powerflow CAI, Osiris & Cypher, 4:56 rear diff gears
SUSPENSION: 9" Fabtech/PRG lift, 3" PA Body Lift, Bushwacker GM Cutouts, Extreme Pinch Weld Mod, Cepek Mud Country 40's, Sway bar removed, Air Lift Air Bags, Roadmaster Active Suspension
EXTRAS: AP Racing 6-Piston Big Brake Kit, Viair Air Compressor, Dunder Grill, Custom reciever lowered to pull a 31 foot travel trailer
WANTED: Front diff 4:56 Gears
Dads_taxi is offline   Reply With Quote
Old 10-27-2009, 10:15 PM   #122 (permalink)
titanridinghigh's Avatar
Send a message via AIM to titanridinghigh
If I remember correctly, the cruise light would just flash.. I really didn't mind back then because I never used it... Did your uprev clear it somehow??
  • 2006 NO FEAR Edition CC TITAN
  • PRO COMP Stage 2 with MX6 Shocks
  • CST Sway Bar Links
  • 35x12.50 PRO COMP Xtreme A/T
  • 20x10 KMC XD Series Monsters
  • Shaved & Pulled Rear Fenders
  • 2008 Rear Axle
  • 5% Tint
  • 6k HID
  • Alpine Indash
  • Alpine PDX 1.1000 & JL 300/4 AMPS
  • Infinity Kappa Components all around
  • 4 10" JL W3 v2 in a Fiber Glass Box
  • Odyssey PC1700 Deep Cycle Battery
  • Bully Dog GT Gauge and Programer
  • Gibson Exhaust with Throw Down Tip
  • Volant Intake
titanridinghigh is offline   Reply With Quote
Old 10-28-2009, 01:49 PM   #123 (permalink)
MacOtac's Avatar
Send a message via MSN to MacOtac Send a message via Yahoo to MacOtac
I spoke with Chad over at Superior Alex and got a quote of, labor $380.00 +parts(how much is Superior charging for Gears?).... Does that sound steep?? Does anybody know where I can get a better deal on install? SoCal? I am looking to go the 4:10 route, Thanks.
Sig: By dOva
"Green Machine"
2005 SE CC 2WD Canteen Green
MacOtac is offline   Reply With Quote
Old 10-28-2009, 10:58 PM   #124 (permalink)
I never did have any codes and the cruise light never flashed for me. Everything works great.
Old 10-29-2009, 08:54 AM   #125 (permalink)
CL 8 2WD's Avatar
Maybe it has something to do with having Big Tow vs Not.
I think I will look into getting a Big Tow flash to see if that is it what you have a XE does it have Big Tow
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 10-29-2009, 11:35 AM   #126 (permalink)
Its an XE.. But from the looks of his sig, I think he has he small mirrors..
Unless he has the offroad package, I'd doubt he had the BT 3.36 before
  • 2008 Rear Axle
  • 5% Tint
  • 6k HID
  • Alpine Indash
  • Volant Intake
Old 10-29-2009, 11:53 AM   #127 (permalink)
rynomx785's Avatar
I've been under the impression for quite some time that aftermarket gears= no cruise control.
Old 10-29-2009, 01:36 PM   #128 (permalink)
Not True. Did tt and superior 3.73 ring and pinion. I still have cruise control and there is no issues with dash lights.
titan007 is offline   Reply With Quote
Old 10-29-2009, 03:01 PM   #129 (permalink)
undy's Avatar
possibly sounds like superior gears keep cc??
2005 CC SE 6 Seat Pop. Package
Exterior: 6" Pro Comp Suspension Lift * 3" Body Lift * 37x13.50x20 Toyo O/C Tires * 20x9 Ballistic Offroad Hostel Black Wheels * Bushwacker Pocket Fender Flares * T-Rex 1 pc. Upper and Lower Grille (black)
Interior: Panasonic CQ-VD6503U DVD/NAV Head Unit * Kicker ZX1500.1 Amp * Kicker ZX350.4 Amp * (2) RE SE 10" Subs * Tech12 Foward Firing Ported Enclosure * Infinity Reference CS6020 6.5" Speaker Set w/ (6) Silk Dome Tweeters All Around * Custom Stainless Nismo Gauges
Performance: Superchips Cortex 87 Tune * AEM Brute Force Intake * Flowmaster Super 40 Series Dumped
Next to come: A lot on my mind
undy is offline   Reply With Quote
Old 10-29-2009, 03:21 PM   #130 (permalink)
rynomx785's Avatar
Starting to sound that way. I don't think that any of the Hoopers trucks still have CC.
Old 10-29-2009, 03:46 PM   #131 (permalink)
MacOtac's Avatar
No, I spoke with Chad as I am going to get 3.73 gears put in and he warns that cruise control will be lost.
I will let you know also, that your factory cruise control may not work, after
swapping your gears out. I've had a set of 4.56's go into one truck, an it
not be affected. I just got a call from another customer this morning, that
installed 4.10's in his, and although no ABS lights came on...his cruise control doesn't work. Currently, I have no solution for this, as I have yet to determine why one would work, and another wouldn't. This is all information that I need to make sure you're aware of.
Chad Jones
Sig: By dOva
"Green Machine"
Old 10-29-2009, 10:31 PM   #132 (permalink)
So this is the way im seeing it so far...
3.73's = No CC
4.10's = No CC
4.56's = Perfectly Fine Cruise Control
  • 2008 Rear Axle
  • 5% Tint
  • 6k HID
  • Alpine Indash
  • Volant Intake
Old 10-30-2009, 01:47 AM   #133 (permalink)
hooligan's Avatar
Chad Jones
that is correct... my friend just installed Superior 3.73s and trutrac in a customers titan and the cruise was lost. not one tech or those in the know can understand why its lost. other than that Superior gears work flawlessly.
born 12/3, purchased 1/4 '04 Smoke SE KC PRG MT kit, CST spindles, PRG Spec'd SAWs 2.5" C/Os w/Eibachs, SAW Airbumps, Deaver 3" springpack, PRG 1" billet blocks, Radflo 2.0 remote res shocks, PRG shackles, CST carrier bearing, PRG Offroad traction bars, 37x12.5x17 BFG All-Terrains, American Racing Mojave Teflons, 35w DDM HID low beams, SpinTech Pro Street custom exhaust, AEM CAI w/DryFlow Filter, IonicDynamics FRP prerunner fenders, front windshield tinted, Optima Yellow Top, Pioneer AVH-4100DVD w/ipod adapter connected to 160gb iPod, Sirius, HD radio tuner, Hertz 6.5" Components front, Boston 6.5" rear, Boston G1 10" subs, tech12 sub enclosure, Alpine amps, Eclipse BEC106 backup camera, TrueTrac, regeared from 2.94s to 4.11s...
>>>>>>>> Lucerne Valley offroad HD videos: http://vimeo.com/groups/h00ligan/videos
>>>>>>>> Lucerne Valley offroad PICS at: www.liftedimports.com
Old 10-30-2009, 09:43 PM   #134 (permalink)
3.73's = No CC
4.10's = No CC
I won't know for sure for a day or two when my rig comes out of the shop with Superior Axle 4.10 gears and ARB RD-149 locker, but I find this discussion to be wacky. Chad called me the day before yesterday to hear what my results were and informed me that a customer cited an issue with their cruise control not working. I know 20 to 30 Xterras that have switched gear ratio to 3.36 to be compatible when they swapped in the M205, I know Xterras running Frontier ring and pinion sets, and not one ever cited a problem with cruise control. Why would after-market gears be any different than the stock ring and pinion...why only in very few cases did the cruise control malfunction...this has zero continuity and lacks logic??? My installer is an expert (builds dragsters, hot rods, monster 4x4), and I'll post my results here very soon, but in the meantime I'm siding with titan007 on this topic, and must assume installer error is the culprit for reported cruise control malfunctions.
LA RANA is offline   Reply With Quote
Old 11-03-2009, 12:29 AM   #135 (permalink)
A lonnnnggg time ago, I believe I read somewhere hear that there is a second speedo sensor in the rear axle..
In this event, if the two sensors (1st being in the tranny) dont match up, than the cc would disengage.
**anyone feel free to add FACTS, because im not sure if this is completely true
  • 2008 Rear Axle
  • 5% Tint
  • 6k HID
  • Alpine Indash
  • Volant Intake
what gears 2wd06titan Titan Engine, Transmission & Drivetrain 7 01-02-2009 11:09 PM
The Gears onelowmini Titan Engine, Transmission & Drivetrain 19 05-22-2007 12:36 AM
Gears? Warp09 Prerunners.com - Titan Leveling Kits 2 04-29-2007 02:13 PM
gears please!! audiocar Titan Performance Modifications 7 03-21-2006 07:47 PM
gears mudfinder Titan Engine, Transmission & Drivetrain 5 10-03-2005 06:03 PM
