Carrier Bearing - Nissan Titan Forum
post #1 of 14 (permalink) Old 08-28-2009, 11:55 AM Thread Starter
iTrader Score: 2 reviews
Carrier Bearing
Hey guys we have a Titan here at the shop and it has a blown carrier bearing seal. I'm looking for a part number or where we can get another one with no luck. Can you guys help?
sideshow is offline
Advertisement
post #2 of 14 (permalink) Old 08-28-2009, 12:34 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: Carrier Bearing
Would that be #4 in teh diagram?
Try this number 38189-8S100
2014 Wrangler Unlimited Sahara
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
post #3 of 14 (permalink) Old 08-28-2009, 01:15 PM
Yahooligan's Avatar
iTrader Score: 0 reviews
Re: Carrier Bearing
I think we have a failure in communication, carrier bearing seal? Do you mean pinion seal? The carrier bearing is #19 and has no seal, the closest thing to a carrier bearing seal would be an axle shaft seal.
The new pup: 2007.5 Dodge Ram 3500 MegaCab SLT 4x4 SRW, Inferno Red
The old dog: 2005 Titan SE CC BT 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, RAS, SnugTop Sport shell, 5000k HIDs - SOLD!
The old fish: 1984 Scarab 21SS - Marine Power 454 - SOLD
The new fish: 1998 Seaswirl 170 BR I/O
Yahooligan is offline
post #4 of 14 (permalink) Old 08-28-2009, 01:21 PM
Re: Carrier Bearing
Yeah, the part number I listed above is for the pinion seal.
post #5 of 14 (permalink) Old 08-28-2009, 01:27 PM
iTrader Score: 4 reviews
Re: Carrier Bearing
I would like to add further confusion. Maybe he is referring to the center bearing for the driveshaft. I have read references to "carrier bearing drop bracket" in connection with people doing lifts.
bestatchess is offline
post #6 of 14 (permalink) Old 08-28-2009, 01:28 PM
Yahooligan's Avatar
Re: Carrier Bearing
Right, I just want to make sure we're all on the same page. He could mean the outer shaft bearing and axle shaft seal, which is common. Guess we'll just wait and see what number he picks. This is kind of like playing the lottery...or bingo...
post #7 of 14 (permalink) Old 08-28-2009, 01:32 PM
Re: Carrier Bearing
That remind me, Mega Millions lotto is $300 million for tonight. BBL.
post #8 of 14 (permalink) Old 08-28-2009, 04:11 PM Thread Starter
Re: Carrier Bearing
I think you are right.
sideshow is offline
post #9 of 14 (permalink) Old 08-28-2009, 04:19 PM Thread Starter
Re: Carrier Bearing
Its funny the Nissan dealership knew what I was talking about when I called. Dealer price was $146.33. I found out that another vehicle uses the same exact piece. $20 from oreilly's. Thanks for the help anyways guys.
sideshow is offline
post #10 of 14 (permalink) Old 08-28-2009, 04:30 PM
Yahooligan's Avatar
Re: Carrier Bearing
Must be for the LWB Titan, because my '05 is a single driveshaft with no such bearing/support.
post #11 of 14 (permalink) Old 08-28-2009, 04:48 PM
Re: Carrier Bearing
2wd has them
4x4 has a shorter rear driveshaft because of the transfer case.
post #12 of 14 (permalink) Old 08-28-2009, 04:53 PM
Yahooligan's Avatar
Re: Carrier Bearing
2wd has them
Ohhhh, forgot about the 2wd!
post #13 of 14 (permalink) Old 08-28-2009, 09:36 PM
loufish's Avatar
iTrader Score: 11 reviews
Re: Carrier Bearing
...ouch......I'm so hurt....
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
loufish is offline
post #14 of 14 (permalink) Old 08-29-2009, 12:16 AM
Yahooligan's Avatar
Re: Carrier Bearing
You're unforgettable, lou.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Linear Mode Linear Mode
Carrier bearing?? emtitan Titan Suspension 18 05-21-2010 01:05 AM
Carrier bearing adub Titan Engine, Transmission & Drivetrain 3 04-24-2009 01:21 PM
Carrier Bearing Drop SinCItyTitan Titan Suspension 27 03-25-2008 07:59 AM
carrier bearing timlloyd951 Titan Engine, Transmission & Drivetrain 1 03-20-2008 08:55 PM
carrier bearing DaFridge Titan Suspension 8 07-03-2005 02:49 PM
You may post new threads
You may post replies
