rear axle leaking - Nissan Titan Forum
post #1 of 10 (permalink) Old 09-10-2009, 10:40 AM Thread Starter
iTrader Score: 0 reviews
rear axle leaking
Need help--I have a 2005 nissan titan 2wd that just turned over 92,000 miles and noticed that I have fluid leaking on rear driverside axle. Does anyone have pictures of how the axle comes apart. My truck has disc brakes not drums-is there a difference in the axles.
RobeTo is offline
Advertisement
post #2 of 10 (permalink) Old 09-12-2009, 03:19 AM
iTrader Score: 1 reviews
Re: rear axle leaking
all titans have disks, and your under the 100,000 mile powertrain... scram to the dealer let them do it.
tiller87 is offline
The Following User Says Thank You to tiller87 For This Useful Post:
RobeTo (09-14-2009)
post #3 of 10 (permalink) Old 09-12-2009, 07:29 AM
loufish's Avatar
iTrader Score: 11 reviews
How many miles is the power train warranty?....What happened to 5 yrs/60k?
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
loufish is offline
post #4 of 10 (permalink) Old 09-12-2009, 07:58 AM
layer1's Avatar
Garage
iTrader Score: 9 reviews
You must have the extended power train warranty.
08.5 SE CC, 4x4, Smoke
layer1 is offline
post #5 of 10 (permalink) Old 09-12-2009, 11:46 AM
iTrader Score: 3 reviews
ya its 60k unless you have extended warranty.
heres the 3rd time mine went at 89k
2010 Pro-4X CC with Pro Comp 7047 and 2" leveling kit.
Molson is offline
post #6 of 10 (permalink) Old 09-12-2009, 04:01 PM
hey, iI have the same problem with my 2006, 90.000 miles and both sies are leaking. I found the following on my search for a manual. Free Chilton Repair Manuals Online - Nissan Forums: Nissan Altima Forum. This fella posted a link to chilton online, it works. I just printed out the exploded view and instructions to fix mine. It also has all the TSB's listed.
Check it out.
Good luck
"Have Blues, will travel"
bluesfan45 is offline
The Following User Says Thank You to bluesfan45 For This Useful Post:
RobeTo (09-14-2009)
post #7 of 10 (permalink) Old 09-12-2009, 04:05 PM
Question Re: rear axle leaking
so, what exactly do we have to replace? Only the seals,or something else?
Thanx
RobeTo (09-14-2009)
post #8 of 10 (permalink) Old 09-12-2009, 09:29 PM
loufish's Avatar
This has been covered oh....about 100 times...
Try a search for "axle leaks" for the many threads about this...if that falls flat, then try again, I'll be glad to help...
Rear Bumpy-Bumps
Born 9/2004
2002 Honda XR650R
loufish is offline
The Following 2 Users Say Thank You to loufish For This Useful Post:
bluesfan45 (09-14-2009), OneQuick06 (09-13-2009)
post #9 of 10 (permalink) Old 09-13-2009, 12:32 AM
OneQuick06's Avatar
iTrader Score: 4 reviews
Mine is 7 years or 100k miles.
Beason's 06 CC BT LE
CrayolaWhore™
MonkeyPumperWhore™
OneQuick06 is offline
post #10 of 10 (permalink) Old 09-14-2009, 05:29 AM Thread Starter
Check it out.
Good luck
Thanks--Just printed out the diagram and instructions on how to remove. I just can't make myself pay dealer prices for this. This is the first problem that I have had with my nissan. Thanks for your help!!!!!!!!!!
RobeTo is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 22 04-24-2015 11:00 AM
Rear Axle Seal Leaking YJTITAN9504 Titan Problems & Dealer Service 10 03-17-2014 12:22 PM
Rear Axle Seal Leaking sigep1967 Titan Engine, Transmission & Drivetrain 2 06-25-2009 05:14 AM
is your Rear axle seal Leaking Stomper4x4 Titan General Discussion 9 12-06-2005 08:25 AM
Rear Axle Seal Leaking?? JimB Titan General Discussion 15 10-11-2005 06:50 PM
You may post new threads
You may post replies
