Re: 3.36 Gears
You can get new carrier bearings, and you would need a new pinion seal and crush sleeve...and a new inner pinion bearing, and I would replace both pinion bearings if it was me...
As far as should you run them, I would have to see it with my own eyes, or in your case have a local trusted rear end shop check out the donor rear end...
I would REALLY do everything you can do to get a T/Trac to replace the diff to replace the weak troublemaking spyder gears...even if you have to wait a couple months to gather up the scratch...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
