How to disable Low Tire Pressure Monitor LIGHT? - Nissan Titan Forum
Titan FAQ & How to Area This area servers as a holding place for all FAQ entires, and Howto Articles.
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
post #1 of 31 (permalink) Old 06-17-2004, 03:33 PM Thread Starter
DallasTitan's Avatar
iTrader Score: 0 reviews
Lightbulb How to disable Low Tire Pressure Monitor LIGHT?
I'm looking to purchase a Wheel/Tire combo(already mounted and balanced) from one of the Internet stores. Since the tires have already been mounted with regular valve stems, I presume if they're installed on the truck, the low pressure light will stay on.
Does it have a fuse to pull so it'll stay off or are there any other factors involved that I should know about?
I didn't want to take the dash apart to get rid of the light bulb so if there's an easier way please let me know.
Thanks,
DT
DallasTitan is offline
Advertisement
post #2 of 31 (permalink) Old 06-17-2004, 03:53 PM
Austin's Avatar
Buy a set of tire pressure sensors from your dealer - $200 (Or have them removed from your OEM tire/wheel combo.)
Have a local tire shop unmount your new tires, install the tire pressure sensors, then mount and balance the combo again. $60-80.
I think having an idiot light on the dash telling you your tire pressure is low and you're in danger of imitating a Ford Exploder is well worth the $60-$300 it may cost you.
MY04 SE King Cab 4X4 SOLD!
- Remaining up
Austin is offline
post #3 of 31 (permalink) Old 06-17-2004, 04:09 PM
z3axv's Avatar
That little light and alarm saved me in the North Georgia mountains. Seems I caught a nail between the treads. The alarm sounded and I figured it was a malfunction, the tires looked OK. Once I arrived at my destination I checked the pressure and indeed one tire was at 25 psi and night was beginning to fall. Had I not had the monitor I would have had to change a completely flat tire the next morning on a gravel driveway with a steep incline.
Black LE 4x2
bod 05/04
'03 Toyota LandCruiser
"Quick to judge quick to anger slow to understand,
ignorance and prejudice and fear, walk hand in hand"
z3axv is offline
post #4 of 31 (permalink) Old 06-17-2004, 08:41 PM Thread Starter
Thanks guys,
I think it's worth the little extra cost.
DT
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
post #5 of 31 (permalink) Old 06-17-2004, 08:43 PM
Austin's Avatar
Great decision!
- Remaining up
Austin is offline
post #6 of 31 (permalink) Old 06-18-2004, 08:43 AM
My light comes on after driving 30-40 miles and the tire pressures are all ok. What a PIA.
2670 is offline
post #7 of 31 (permalink) Old 06-18-2004, 11:59 AM
Austin's Avatar
The trip for the low tire pressure warning light is 28psi. If all your tires are above that pressure, then you likely have a malfunctioning sensor.
That's covered under warranty, so let the dealer plug their consultII in, verify the bad sensor and replace it.
- Remaining up
Austin is offline
post #8 of 31 (permalink) Old 08-17-2007, 02:22 AM
AF-Medic's Avatar
iTrader Score: 4 reviews
Re:  уплю Windows
Originally Posted by kupluwin
 уплю Windows  уплю Office -Vista/XP/2003 kupluwin@mail.ru
и другой Ћ»÷≈Ќ«»ќЌЌџ… софт
пишите на е-мейл kupluwin@mail.ru
Ban that crap
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's, Two 12 volt tech underseat subs with CDT 4100 and cdt replacment door speakers,MD DVD player with 8.5 screen Shift Pass You
AF-Medic is offline
post #9 of 31 (permalink) Old 08-20-2007, 01:25 PM
BuckyBadger's Avatar
iTrader Score: 11 reviews
Re:  уплю Windows
Damn Russians
Back on topic, will the TPS light some on when the pressure is too high?
BuckyBadger is offline
post #10 of 31 (permalink) Old 08-20-2007, 02:44 PM
Duner49's Avatar
iTrader Score: 1 reviews
Re:  уплю Windows
Originally Posted by BuckyBadger
Damn Russians
I have had 80psi in my tires once and the light did not activate. Its just a low pressure warning system.
2006 KC SE 4x4 Big Tow and Off Road Pkg - R.I.P.
2005 Raptor 660
2003 Yamaha R1 - R.I.P.
Duner49 is offline
post #11 of 31 (permalink) Old 11-25-2007, 07:31 PM
jaho1979's Avatar
Re: How to disable Low Tire Pressure Monitor LIGHT?
Mine too, completely worthless.
2006 Crew Cab 4x4 LE
jaho1979 is offline
post #12 of 31 (permalink) Old 11-27-2007, 07:38 PM
Titan671's Avatar
Send a message via Yahoo to Titan671
Since getting a set of aftermarket rims, I have not had a problem with the low pressure sensor light turning on. I had originally installed the OEM sensors on the aftermarket rims, but due to the angle of the OEM stem valve, I couldnt use them. I inquired from the tire shop if that would set off my sensors. The tech informed me that since the OEM spare tire still had a sensor, the ECU will still read it as if I still had my OEM wheels on. I didnt believe him, but its been a year now and the low pressure sensor light has not turned on. I was kinda suspicious so I reinstalled my OEM wheels. After running them for a week, I ran over a nail and started a slow leak. After a day or two, the low pressure sensor light turned on. I refilled the tire with air about 40 psi and the light turned off after driving it for several minutes. I guess the tech was right..it worked for me.
2004 CCB LE w/ tow package
UpRev and Osiris tuned with supports from Chris and Randy and the member of TT and CT.
Titan671 is offline
post #13 of 31 (permalink) Old 11-29-2007, 11:05 AM
bigfinderman's Avatar
Send a message via Yahoo to bigfinderman
Hmmm. I had my little 17 in chromies put on when i bought my truck and they were also designed to were i couldn't use my sensors.. And my dam light has been on ever sense.... It irritates the sh*t out of me...
06 Smokd out XE KC
2* Timing advance
Magnaflow Exhaust
Airbox Mod with K&N
Dropped 2" in rear
Powerstop drilled/slotted kit
Tint
bigfinderman is offline
post #14 of 31 (permalink) Old 01-01-2008, 09:10 AM
Banned
Post всех с новым годом!
желаю вам успехов, как в работе так и в повседневной жизни!
пусть новый год вам принесЄт намного больше чем уход€щий!
побольше вам улыбок и удачи во всех начинани€х!
всегда ваш,
дед мороз!
BestOfDedMorozy is offline
post #15 of 31 (permalink) Old 01-01-2008, 10:55 AM
MuskyHunter's Avatar
iTrader Score: 2 reviews
When using two different sets of wheels, each with its own sensors, is there a programming involved when switching between wheels?
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage : BFG Long Trail TA Tour Tires: Bilstein 5100 and Icon Shocks : Frozen Rotors : Hawk LTS Pads : Goodridge Gstop Brake Lines
MuskyHunter is offline
The Following User Says Thank You to MuskyHunter For This Useful Post:
mtp (06-24-2013)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
You may post new threads
You may post replies
