Repair Cup Holder - Nissan Titan Forum
Titan FAQ & How to Area This area servers as a holding place for all FAQ entires, and Howto Articles.
post #1 of 9 (permalink) Old 05-08-2012, 08:23 PM Thread Starter
Kronos1965's Avatar
iTrader Score: 0 reviews
Repair Cup Holder
If you have a bench seat and the cup holder at the bottom has broken because the tabs that connect to the assembly were broken, I have a fix that has worked well.
Tools needed:
1. Dremel tool or Multi max (worked perfectly)
2. #12-24 x 1/2 machine screws
3. Superglue to bond metal and plastic
4. metal drill bit for #12 hole.
5. Simpons Strong Tie A21z L bracket
Repair Cup Holder-metal-blade.jpg   Repair Cup Holder-machine-hinge-screws-12x24.jpg   Repair Cup Holder-a21z-simpson-bracket.jpg
HippieWhore™
Be the kind of person your dog thinks you are.
Kronos1965 is offline
The Following User Says Thank You to Kronos1965 For This Useful Post:
LoveHammer (05-10-2012)
Advertisement
post #2 of 9 (permalink) Old 05-08-2012, 08:28 PM Thread Starter
Kronos1965's Avatar
Re: Repair Cup Holder
Step One: Remove existing plastic bracing behind cup holder so the surface is smooth. You will glue the new bracket to there.
Step Two: Very important! Mark the location of where the old tabs were so that you can drill new holes in the metal bracket. The screws will now go outward as opposed to the old tabs which went inward.
Step Three: Drill holes
Step Four: Shave off metal L bracket so that it lines up with OEM bracket.
Step Five: Insert new screws so that they are aimed outwards and into the existing cup holder eyelets. The tension will keep them together. I do not recommend gluing both of them as it makes removal impossible. (in case of course you decide to break the OEM eyelets!
Repair Cup Holder-101_3584.jpg   Repair Cup Holder-101_3578.jpg   Repair Cup Holder-dsc03738.jpg
HippieWhore™
post #3 of 9 (permalink) Old 05-10-2012, 09:05 PM
iTrader Score: 1 reviews
That's awesome! I now have a weekend project.
2008.5 Red Alert Pro-4X King Cab FFV
6in. Rough Country Lift
Airaid 4" intake, FT90, JBA EVOL Cat Back, TB Bypass, Transgo Shift Kit, Uprev, Moto Metal 951s with 35" Cooper STTs, Bilstein 5100s up front - crappy RC shocks out back, RAS.
LoveHammer is offline
post #4 of 9 (permalink) Old 05-14-2012, 06:46 PM
jay2904's Avatar
Thanks........
jay2904 is offline
post #5 of 9 (permalink) Old 06-12-2012, 10:34 PM
Nice... I see this fix coming up in my very near future. Good job!
2005 Nissan Titan SE
Custom Exhaust
Nav/Sound/TV screen (New system incoming)
Power lock kit installed
Custom "shortened" wire loom (thanks to the guy that cut all the lines...)
The guy bought a custom sound system, but manual locks & windows. WTF?
md123180 is offline
post #6 of 9 (permalink) Old 10-02-2012, 07:53 PM
Where do you get the bracket from? Is it a Home Depot type item, or custom order online?
2008.5 Majestic Blue Titan CCSB, 2wd
Performance: Airaid MXP, PRT B-Pipes, TBB, Hypertech tuned.
Exterior: Blacked out Projector retrofit w/ LEGIT 5k HID, AR Mainline 20" wheels w/ Pirellis
Stereo: Pioneer X4600BT, MB Quart Components Front and Rear powered by Phoenix Gold Amp, Tech12v box w/ two 10" Sundown subs and CT Sounds amp, DIY grounding kit
2005 Yamaha R1
BST Carbon Fiber wheels, full Akro exhaust, Full Ohlins, Slipper clutch, Upgraded levers, rear sets, lines and rotors, HIDs/LEDs, etc.
jjminch is offline
post #7 of 9 (permalink) Old 10-02-2012, 08:24 PM
Home Depot has the Brackets.
2011 Titan KC, 4 X 4, (part time "work truck"), TracRac,
Galaxy black.
HoneyB is offline
post #8 of 9 (permalink) Old 12-03-2012, 02:06 AM
Thanks for the post. I was able to modify your technique and come up with this concept for a repair. Menard's has a cushion clamp, 1/4 x 1/2. After making some mods of the bracket, works perfect for my needs. Total cost was $0.59. The clamp had to be flatten for the cup holder assembly to fit back into the console.
Repair Cup Holder-68450_4143946078803_514874039_n.jpg   Repair Cup Holder-309246_4143944358760_1407776915_n.jpg   Repair Cup Holder-6979_4143949638892_45057343_n.jpg   Repair Cup Holder-154492_4143947718844_1641609166_n.jpg   Repair Cup Holder-319572_4143954519014_1513755736_n.jpg
Eau Claire is offline
post #9 of 9 (permalink) Old 12-03-2012, 02:14 AM
Caution where the screw goes into the holder. Need to keep in mind of avoiding the hinge.
Repair Cup Holder-319572_4143954519014_1513755736_n.jpg   Repair Cup Holder-228293_4143955679043_558159796_n.jpg   Repair Cup Holder-598469_4143956039052_920780187_n.jpg   Repair Cup Holder-526686_4143958319109_120492890_n.jpg   Repair Cup Holder-155973_4143953598991_1366439030_n.jpg
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Where can you get tag holder jonwalden68 Titan General Discussion 5 04-12-2012 09:37 PM
Cup holder LED done deerslayer Titan Pictures & Media Post 2 02-11-2011 02:57 PM
Front Diff. Repair or Not Repair Slugger Titan Engine, Transmission & Drivetrain 5 12-01-2010 12:39 PM
Battery Holder futurejd1 Titan FAQ & How to Area 1 06-10-2008 05:31 PM
Cup holder PRJ Titan General Discussion 0 10-28-2004 11:59 AM
You may post new threads
You may post replies
