How To Replace Headlight Bulbs - Nissan Titan Forum
Titan FAQ & How to Area This area servers as a holding place for all FAQ entires, and Howto Articles.
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
post #1 of 62 (permalink) Old 11-30-2005, 09:44 PM Thread Starter
scr38's Avatar
iTrader Score: 0 reviews
There is a easy way to get to the headlight bulbs to replace them.
1. First, remember to not touch the glass on the bulbs. Doing so may cause early failure of the bulbs. I use clean white cotton gloves when installing the bulbs.
2. Turn the steering wheel all the way to one side.
3. Look in the fender well at the plastic liner. Directly behind the headlight you will find a Phillips screw. This screw is in a recess in the fender liner. Remove this one screw.
4. The fender liner can now be easily pulled back to get access to the bulbs from the bottom.
5. Disconnect the wiring plug from the bulb.
6. The bulb can now be rotated to remove.
7. Reverse the procedure to install the new bulb.
scr38 is offline
The Following 11 Users Say Thank You to scr38 For This Useful Post:
951jimbo (11-12-2014), alby (03-30-2009), bum76 (01-14-2011), cralock (09-25-2014), donnelly (10-20-2009), fish (12-07-2012), gmorris (08-07-2014), jray (01-22-2010), Misfit (04-24-2010), optitan (08-13-2010), TJ Banks (03-17-2010)
Advertisement
post #2 of 62 (permalink) Old 12-22-2005, 10:21 PM
Ditch64242's Avatar
iTrader Score: 1 reviews
Send a message via AIM to Ditch64242 Send a message via MSN to Ditch64242 Send a message via Yahoo to Ditch64242
Re: How To Replace Headlight Bulbs
any chance on photos?
Ditch64242 is offline
post #3 of 62 (permalink) Old 10-11-2006, 05:34 PM
JGM
Here is a few shots I took while putting in some sylvania silverstars of the screws that needed to be removed on a '05 titan and shots of the blinker and lowbeam on the driver's side.
The passenger side is the same, just mirrored.
How To Replace Headlight Bulbs-light_access.jpg   How To Replace Headlight Bulbs-low_beam1.jpg   How To Replace Headlight Bulbs-low_beam.jpg
JGM is offline
The Following 4 Users Say Thank You to JGM For This Useful Post:
951jimbo (11-12-2014), alby (03-30-2009), cralock (09-25-2014), donnelly (10-20-2009)
post #4 of 62 (permalink) Old 10-11-2006, 06:23 PM
This can be a tricky one, but, once you do it, it's like riding a bike....
Grillz10 is offline
post #5 of 62 (permalink) Old 10-11-2006, 07:24 PM
JGM
Indeed, the few things I found to be the real tricky that might get someone caught if they have never done it is getting the bulbs in and locked back into place properly, getting them out is easy, but it took a few attempts on each bulb to get the socket flat and level, if not it turns hard and does not quite lock in, and you can see the funny angle of the bulb when you get infront of the truck. Also keeping the bulb clean while putting it back in, remembering to wear latex (or non latex if you are alergic) gloves and I cleaned the bulbs even though I had not touched the low beams, just to make sure they would have nothing on them to create a hot spot, I just used rubbing alcohol and a soft lint free cloth to clean them.
JGM is offline
post #6 of 62 (permalink) Old 10-28-2006, 10:05 AM
thebassn8tr's Avatar
iTrader Score: 63 reviews
Thanks for the How to! I just put my chrome turn signal bulbs on. Couln't have been easier (thanks to your post).
thebassn8tr is offline
post #7 of 62 (permalink) Old 10-28-2006, 10:10 AM
royr's Avatar
iTrader Score: 5 reviews
Smile Re: How To Replace Headlight Bulbs
Graet Thread - sure beets pulling out the whole grill and everything! Thanks!
royr is offline
post #8 of 62 (permalink) Old 01-02-2008, 08:19 AM
Thumbs up Re: How To Replace Headlight Bulbs
great thread... i did mine in about 30 minutes total. only need to remove two screws on the fender liner. also, it's easier to remove the plug from the high beams if you do it from above. bulbs only need to rotate 1/8 of a turn to the right, so just make sure all three tabs are seated correctly before turning new bulbs back into position.
cotitan07 is offline
post #9 of 62 (permalink) Old 01-02-2008, 01:04 PM
chunko's Avatar
This may come in handy for my HID Install tonight.
Thx
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
chunko is offline
post #10 of 62 (permalink) Old 01-02-2008, 01:31 PM
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
where's my blinker fluid reservoir?
only had to replace the tails thus far.. hadn't even really looked @ the heads
2004 Sedona Titan LE CC 4wd
75,000 mi. 1/22/14
86.000 mi. 8/20/15
96,000 mi. 12/02/16
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
PA Chapter Director
Link to MVP Titans Facebook Page
I should stop having my suit dry cleaned, it seems to kill people.
I'm not worried, I have a Titan with 4wd and a pair of balls.
You can lead a moron to knowledge but you cannot make him think.
I should probably buy more bullets.
The darkest hour is before the dawn.
The Urinator™
DeadRiver is offline
post #11 of 62 (permalink) Old 01-02-2008, 08:52 PM
rgregory1965's Avatar
iTrader Score: 6 reviews
Blinker fluid right next to the radiator oil cap.
rgregory1965 is offline
post #12 of 62 (permalink) Old 01-03-2008, 05:39 AM
Galaxyblack's Avatar
Yeah, if you install Silverstars you get to do it often. They don't last for S**t You will get good at replacing them.
2004 LE 4X4 Crew Galaxy Black, Leer 100R shell, Chrome tailgate trim, Chrome stock wheels, chrome door sills, Zoomers cat back, 2*advance, 150,000 miles going strong. Traded on a loaded Dodge 1500 Laramie, heaven help me!
As my dear old Dad said, "You've got to stop and smell the roses once in a while". He didn't.... I plan to know the smell of them roses intimately.
Galaxyblack is offline
The Following User Says Thank You to Galaxyblack For This Useful Post:
alby (03-30-2009)
post #13 of 62 (permalink) Old 01-03-2008, 05:50 AM
Juday's Avatar
If you don't mind me asking, what is the product number of the Silverstars that you installed? Are there any alternatives to the Silverstars that I can buy at my local AutoZone, AdvancedAuto, NAPA, etc.? I don't much like the low luminescence of the stock headlights and I'm wanting something brighter. But, I'm not going to buy the HID kit from China because it doesn't bother me that much.
2012 RAM Power Wagon
285/75R17 BF Goodrich T/A KM2s | Carli Front Differential Cover | Aluminess Front Bumper | Aluminess Rock Sliders | PIAA 540 Fog Lights
Juday is offline
post #14 of 62 (permalink) Old 01-03-2008, 09:48 PM
Buildwonder's Avatar
iTrader Score: 8 reviews
I installed Silverstar Ultras for high and low beams in my Titan. Highs are 9005 and lows are 9006. I don't have fog lights so I'm unsure of what to use for them. I actually bought mine from eBay and saved an a**load of money. I spent the same amount for both pair with shipping as one pair costs at Pepboys and similar. Pepboys was actually running a $20 rebate per pair for a while. Check their website and see if they're still offering it.
I will say that these bulbs are much whiter and fairly brighter than the stock halogens but really pale in comparison to the HID kits everyone is clamoring over. Silverstar Ultras are perfectly fine for me though. I don't need to see through things or scar the retinas of oncoming motorists as I scorch the roadways with Chinese HID photon cannons.
Lastly, it really is as easy as everyone says to change your bulbs. It took me less than 15 minutes for both sets. Good luck!
Buildwonder is offline
The Following User Says Thank You to Buildwonder For This Useful Post:
alby (03-30-2009)
post #15 of 62 (permalink) Old 01-04-2008, 05:24 PM
RangerNewbie's Avatar
Let me just add that 2 days and 15 minutes to change mine- 2 days to find a post with the fenderwall access secret- and 15 minutes to change the darn bulb
2006 Titan 4X4 Off-Road w/ Tow package- Stock
1997 Ford Ranger 4x4 - Slightly Modified
http://www.cardomain.com/id/RangerNewbie
RangerNewbie is offline
The Following User Says Thank You to RangerNewbie For This Useful Post:
Mrlunchbox (06-16-2014)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Headlight to Headlight Grille? Turbo_neon Titan Interior Discussion 12 04-28-2010 07:11 AM
FS 893 Bulbs used 2 days 1BadTitan Buy/Sell 4 04-24-2005 09:50 PM
changeing headlight bulbs pkramjr Titan General Discussion 6 04-24-2004 05:37 AM
You may post new threads
You may post replies
