Back Up Lights? - Nissan Titan Forum
Titan FAQ & How to Area This area servers as a holding place for all FAQ entires, and Howto Articles.
post #1 of 9 (permalink) Old 02-04-2008, 09:44 PM Thread Starter
RyBo's Avatar
iTrader Score: 23 reviews
Send a message via AIM to RyBo
Back Up Lights?
Quick question about wiring auxillary back-up lights...i was planning on mounting two lights beneath the rear bumper to act as "brights" for my reverse lights, but i was curious to see if I could just simply tap into the reverse lights so that the auxillary lights turned on when the truck was put into reverse. OR, would there be a way to have the lights powered with a toggle switch AND have them work with the reverse lights?
Hope this makes sense, if not I'll try and draw a diagram or something to help out...
Thanks!
Ryan
with way to much to list...
Starting a company but I can't tell you about it until I become a site sponsor...
RyBo is offline
Advertisement
post #2 of 9 (permalink) Old 02-04-2008, 10:42 PM
TitanTeamRoper's Avatar
iTrader Score: 0 reviews
Send a message via Yahoo to TitanTeamRoper
Re: Back Up Lights?
I just did the exact same thing on my trailer, if you have the trailer plug you might be able to tape into that, I was thinking of trying to do it the same thing on my truck. I used an on/on toggle switch; one side reverses light and the other side power from the plug. With the power from the plug I like the fact that the key has to be turned to on to get power to the trailer plug, I would forget they are on and drain my battery.
CURRENT:
2008 Audi A4 quattro
2005 Audi A4 2.0 Turbo
PREVIOUS:
SOLD to Marvelous Matt
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
TitanTeamRoper is offline
post #3 of 9 (permalink) Old 02-04-2008, 11:12 PM Thread Starter
RyBo's Avatar
Re: Back Up Lights?
Don't have a trailer hitch yet but thats not a bad idea...well best thing you can do is get a toggle switch with an led on it so that'll remain on if there's any current going through it, and you'll just have to make a mental note to remember to check after you use em
RyBo is offline
post #4 of 9 (permalink) Old 02-15-2008, 12:07 AM Thread Starter
RyBo's Avatar
Re: Back Up Lights?
Bump....Anybody?
RyBo is offline
post #5 of 9 (permalink) Old 02-15-2008, 05:34 AM
BK19702's Avatar
iTrader Score: 1 reviews
Re: Back Up Lights?
Check if your pre-wired with the plug (should be tucked behind the bumper), hitch or no hitch. I think that's your best bet as far as not worrying about a switch or anything like that.
Truck - 2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSOIL throughout
Toyo Open Country AT's 265/70/17
Prodigy Brake Controller
Curt WD Hitch & Sway Control
Nicely Leveled with 2008 Springs (thanks Greg!)
Trailer - 2002 Shasta 19DB
Stock except for a nice wall clock and new shower head
BK19702 is offline
post #6 of 9 (permalink) Old 02-15-2008, 07:32 AM
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: Back Up Lights?
I wouldn't try to run off of the existing circuits. The amp draw will be too high. Run new wires.
Yes, you can wire them such that the aux will come on automatically with the existing backups, OR come on manually. Two relays are required. You'll have one relay (the one that actually supplies the power to the backup lights) that will have two feeds to trigger it. One feed from the switch, and one from the other relay which is triggered by the tap you WILL have to do on the existing backup light circuit.
Two relays prevents the current from backfeeding the current regardless of whether the switch or the lights are triggering the main relay.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
post #7 of 9 (permalink) Old 02-15-2008, 07:36 AM
iTrader Score: 4 reviews
Re: Back Up Lights?
You could use a relay so as to make sure not to overload existing circuits when towing a trailer. Use a toggle switch to switch the trigger lead of the relay. In one position of the toggle switch, the trigger lead is connected to a circuit that comes on with the ignition. (e.g. lighter socket circuit - so as not to accidentally drain the battery). In the other position of the switch, the trigger lead is connected to oem backup lights or oem trailer backup light connection so that the relay is triggered when you shift into reverse. You could also use a switch with a center off position so that you could switch the lights off while backing up if you wanted. (e.g. a cop is parked behind you and you don't want to nuke him with the aux backup lights).
This would require running a power wire from the relay to the aux backup lights at the back of the truck and a small diameter wire from the relay trigger contact into the cab. The relay would be located near the battery.
bestatchess is offline
post #8 of 9 (permalink) Old 02-17-2008, 08:23 AM
Re: Back Up Lights?
If you just splice wires with the existing backup light circuit, everything will be way too dim at best. At worse, you will hurt stuff. I had a shop do a hack job on mine and I was getting about half the maximum brightness out of everything. To wire into the stock reverse lights and make it work right will involve a diode and a relay or two relays. I don't have diagrams or anything and I'm not an expert but I just know these things from having someone do it right and walk me out and show me what was involved. It IS possible as I have it setup so they come on with a switch or when I throw the truck in reverse, but it gets a tiny bit more complex than just running them from a switch.
Remember.. the stock reverse lamp wires are designed to carry power to weak bulbs that are maybe at most 30-35 watts. You put something else on that circuit, you know have a set of 55 watt and 30 or 35 watt bulbs but working off the same wires that are only designed to power the stock reverse lights.
eharri3 is offline
post #9 of 9 (permalink) Old 02-17-2008, 07:17 PM
bills1974's Avatar
iTrader Score: 7 reviews
Send a message via AIM to bills1974
Re: Back Up Lights?
PIAA 1500 Aux Backup Light System
Take a look at my setup...I just did this yesterday, there is a three way toggle switch (off, on, on with reverse lights). You definately want to run your main power off the battery, you won't have enough juice just tapping into the reverse lights.
To make it come on with your reverse lights: If you look under the truck where the plug goes into the back of your lights, the blue and red striped one is the power feed to your reverse lights.
2014 Jeep Wrangler Unlimited
Cowl Done With Bedliner
Radiator Bypassed - Transmission Fluid
Wife's Ride: 2016 Infiniti QX70
My Other Ride: 2016 Tidewater 230 CC
AKA: Crossdresser Whore™
The Bald Avenger®
"It's really bad when I have to go into the fridge to count how many beers I had last night because I lost track."
"Why is the rum always gone?"
bills1974 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Test Drove Tian & F150 back to back. HSrider Titan General Discussion 22 12-23-2009 07:48 AM
My white back up lights don't turn on when my boat is hooked up. thebassn8tr Titan Towing & Hauling 6 12-06-2006 09:17 AM
Back up lights TitanicCaptain Titan Parts & Accessories 15 11-18-2006 06:11 PM
back up lights hondarider227 Titan Parts & Accessories 17 10-21-2005 10:17 AM
Dealer back up lights chue Titan General Discussion 6 12-09-2004 08:48 AM
You may post new threads
You may post replies
